Question about Acer Aspire 3000 Notebook
Jumpy screen after bump
My laptop got bumped and now the screen is jumpy when it starts up. I suspect that it is something loose in the display. It's funny because the screen stops being jumpy after the laptop has been on for a while, but the initial jumpiness is getting worse with each restart. Should I take the lcd apart to see if something is loose? Are there any good tutorials out there about how to do this?
  • Anonymous Mar 19, 2014
    Screen keeps jumping.
    Problem Solver:
  • 5 Answers
I would agree with you that something is loose. You better stop using the notebook and fix the problem first, because loose connections will get your laptop short circuit.
  1. Check connection from the lcd to the ribbon wire, make sure its frimly attached and sealed with tape.
  2. Check the other end of the connection on *********** board. It's usually seated firmly on a socket.
Posted on Mar 20, 2008
My screen is jumpy with lines across the screen
you need to adjust the refresh rate of the screen if it is a desktop monitor simply press the menu button on the monitor and go through thee adjust display settings or if it is a laptop go to the run bar and search for display settings
Jul 29, 2012 | Acer Aspire 6930-6771 Laptop
1994 940 Volvo wagon turbo has intermittent electrical problems. Blinker on dash stays lit. Dash lights go out but will come back. Radio stopped working then both radio and CD player stopped working all...
It truly sounds like a loose or faulty/corroded ground wire. Almost 99% of the electrical problems I have experienced with Volvo's are loose wire related. There are a number of ground wires underneath the hood grounding the engine. However my first suspect would be the connections on the alternator and battery.
Hope this helps.
Sep 18, 2011 | 1994 Volvo 940
I put a game in the NES Console and it was jumpy and I couldn't play it so I tried another one I was able to play it for a little bit then the screen started getting jumpy. I thought it could be the...
Well there might be something internally wrong with the console like the graphics card
is broken or if just might be on its last life then. If its on a digital tv you need the av cables for it to work then instead of the rf switch.
Jul 02, 2011 | Nintendo NES Console
VHS Grabber has very jumpy screen before I start VHS to record and when recording the playback is also jumpy.
rewind tape then fast forward to the end as the tension on the tape is wrong.
PS put it in a rewinder machine ...ok?
Apr 04, 2011 | Computers & Internet
Audi A4 2009 2.0T CVT jumpy
sound like 1st gear might be slipping or stripped
Nov 15, 2009 | 2009 Audi A4
Amp volume is irregular, jumpy, and produces a muffled tone
SOunds like the emulated line out is the problem IT may be defective. Is this a button or a knob? It may have dirty contacts and MIGHT be able to be cleaned with electronic contact cleaner.
Oct 04, 2009 | Music
Philips x57 laptop. screen has suddenly went fuzzy. distorted colour and images jumpy.
Have you set the right screen resolution. Check screen resolution & color quality setting in display properties.
Aug 17, 2008 | Computers & Internet
Thinkpad T61 Display Problem
LCDs are not repairable, it is something you need to replace when defective. They also happen to be very very expensive to replace.
Is the screen cracked at all? cause sometimes when laptops get bumped, it is actually just the lcd cable inside the laptop that came a little loose and isn't making a full connection. If the screen isn't cracked or anything I would at least look into a possible loose cable first If you are not comfortable taking the laptop apart, I would bring it to a computer shop and have them take a look at it as some laptops can be complicated to open up. They shouldn't charge you more than about $40 to take a look at the lcd cable, they are normally pretty quick to get at. It is worth a shot as lcds typically range from $400 - $1000 and to have someone install it would be probably another $50-$100
hope this helps a little
Mar 21, 2008 | Lenovo ThinkPad T61 Notebook
Lcd disolay has liens through it and colors are off.
If tapping the screen (on sides or back of case - not the screen itself !) affects the display it is usually loose connections either at the motherboard or behind the display where ribbon cable connects. relatively easy repair for someone who can take apart a laptop but you need the repair manual because there is a sequence that needs to be followed.
Feb 19, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3000 Notebook Logo
235 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
