Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Blurry screen When watching my 60" Philips Rear Projection TV, the picture is sometimes fuzzy or blurry. Any suggestions? Thanks!
  • 149 Answers
Coolant fluid on picture tube may be contaminated replace it an setbe ok (this is a technician job)
Posted on Mar 29, 2008
SOURCE:
Blurry screen
I have researched your set. There isn't a date of production that is available so your guesstimate of 11 years old is about where I would place it.
For your specific problem (which is common among old style projection TVs) it's usually the three picture tube or "guns" are showing their age. If it has slowly become more blurry then that is the case. If it has suddenly become blurry then there may be a fixable defect. Judging by it's age I would suspect that your are up for replacing all three tubes in your set. My recommendation is DON'T DO IT. You will be much better off purchasing a newer and preferably flat screen TV. All projection TVs with picture tubes in them typically last between 10,000 and 20,000 hours of operation. At 11 years your set is in that range if you watch an average amount of TV. Enjoy looking for a new set and pick out something that tickles your fancy. Sets have improved vastly with the thin screen technology.
Zashiban
Jun 23, 2010 | Philips 60P8241 60" Rear Projection...
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
My 60 inch Maganvox tv is blurry and the letters at the bottom are blurry. Can;t hardlt make out the picture now.
Replace STK convergence chips there are two next to the heat sink.Unsolder old and solder in the new.
May 21, 2010 | Philips Magnavox 9P6034C 60" Rear...
Philips blurry 34pw8502/37 Blurry Screen
a part called picture tube base which connects picture tube to circuit board got some trouble,,, u can replace it with the help of a service pro..
Mar 23, 2010 | Philips 34PW8502 34" TV
Tv picture blurry, not clear
The LXI or Sears brand used philips TV's. These sets are known for bad coolant fluid. In between the picture tube and their lenses is a layer of clear coolant. Over time the coolant breaks down and causes the picture to become blurry. This can be a complicated repair involving removal of the picture tubes and lenses. Have a repair shop check it for you. Thanks for using fixya.
Dec 12, 2009 | Televison & Video
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
Sep 06, 2008 | Philips 9P5034C 50" Rear Projection...
Rca tv picture blurry and arched up at bottom
Replace the Sanyo I.C. chip on the heat sink of the power supply convergence board STK730-XXX. Last 3 could be 130/010/020, any will work.
http://www.electronix.com/catalog/product_info.php/cPath/6_308/products_id/9541
Sep 20, 2007 | RCA P60921 60" Rear Projection Television
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
346 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
