Question about One For All Televison & Video
One for all URC-6017B00
Lost code sheet for above 'oneforall" model. My machine for it to work on is a
SHARP TV/VCR COMBINATION.
does anyone have the codes?
Many thanks!!
SOURCE: i have a total control
wats the code for a digitor tv using total control
Posted on Jan 20, 2009
  • 242 Answers
SOURCE: I need the remote control
Go to this page, the download of the manual of your remote will automatically start. From page 123 you can find the codes for several brands. On page 129 you can find the codes for Pioneer. Just try them until you find one that works.
The manual also explains how to set up the remote for your dvd-player.
Posted on Apr 03, 2008
IrishDruid
  • 2712 Answers
SOURCE: REMOTE CONTROL SET UP CODE
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: need codes for all for
Good day, I need codes for all for one tv remote control model urc -3430/7540
Posted on Jul 18, 2008
SOURCE: need manual/code book for oneforall.com remote for toschiba tv
NEED TO RESET REMOTE (NEED THE CODE FOR A MITSUBISHI BIG SCREEN)
Posted on Sep 16, 2008
I need codes for the oneforall remote for a sharp tv.
You can download the PDF of the manual here:
http://www.hifi-remote.com/manuals/manual.shtml?URC-3021
But as for your question Sharp TV codes are:
0093
Only one listed in manual.
Apr 30, 2010 | One For All URC-3021 Remote Control
Sharp tv /oneforall/remote control
Press code search button,The indicator light go on.Press the TV button opiton the light will blink.Sharp TV codes 173,095,171,004,006, 012,029,111,112,113,122.After your code is entered,the indicator light will turn off.Aim the remote at your TV and press the ON/OFF button.Your TV should turn off or on.Tries each code until u have ur code.Please rate me after,
if I help U.
Aug 29, 2009 | One For All URC-4330 Remote Control
Hi, i need the code for panasonic model pv-dm2093 so can work with oneforall remote control urc-330b03?
Greetings!
Closest model I had in my files was the URC-3300. I have included the link to the codes for this model: http://www.oneforall-na.com/list_codes.php?db_value=access4&remote_choice=URC%203300
The problem you are going to have is that it is a combination and worse yet, a three play combination. My advice would be to take back the universal remote (provided you just bought it) and get your money back. Then contact www.encompassparts.com They have the oroginal remote control for your unit in stock for around $29.00 plus freight. The remote part number is LSSQ0372. On a combination player I have always maintained it is best to have the OEM remote. It makes life a WHOLE lot easier.
Good Luck!
Rob
Jan 14, 2009 | Panasonic PV-DM2093 Triple Play 20 in....
I need the code for one for all urc-3021 for an apex tv
It is one of the four digit codes listed here 0748 0765 0767
Here is the product page,
http://www.oneforall-na.com/remote.php?type=URC%203021
Here is the Code page
http://www.oneforall-na.com/list_codes.php?db_value=expert4&remote_choice=URC%203021
And here is the Programming steps page
http://www.oneforall-na.com/set_up_remote.php
If this helps, please dont forget to rate it FIXIT!
Thanks,
Charles
Jan 08, 2009 | One For All URC-3021 Remote Control
Code for urc 4220 oneforall remote
I'll let you know soon if it's available..
May 11, 2008 | Daewoo DVQ13H1FC 13 in. Combo
Televison & Video Logo
930 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
