Question about ASUS A8N-SLI Motherboard
I have a asuse (A8N-SLI-DELUXE) with the nforce 4 sli chipset wont let me install any os.
The computer was running slow at first, shut it down, went in to turn it on, didn't turn on. I took the battery out to clear the bios/cmos, turned it on, put battery back in, then the os was missing, so i worked on intalling windows vista, fedora core, linux, suse, all would install, on reboot, the operating system was missing everytime, i re-wired all components to the motherboard, also checked all bios/cmos settings. During the os installs, they were running slow. To me it seems that the install information is not writing to the hard drives, if it is, then something else is wrong, hopefully nothing serious. Need some advice, options, please help.
  • Jim Tice
    Jim Tice Mar 22, 2008
    Hey! Onlinepc-fix lee,
    Thanks for the tip on bios jumper reset, that was part of the problem, no beeping sense it didn't even turn on.. The unexplainable was how did the pc crash after i turned it off,because the next day upon turning it on, just didn't work, after re-setting the battery, it was missing the operating system. Finally changing some jumpers, along with changing the bios settings, i finally got windows vista home premium on there, and re-registered vista with microsoft, so now im back up running really nice, just have to finish on installing all of my programs. also a few more operating systems. I'm now running around 3,000 gig's, should be smooth sailing from here, if you see my name pop up again it's something serious, check you out later, thanks again.
    knoppteria4
    Problem Solver:
  • 7 Answers
Call ASUS !~ I have a CROSSHAIR With the Same Dang Problem(s) They WILL WALK U THROUGH IT !
~ D_Dave
Posted on Mar 25, 2008
    Problem Solver:
  • 18 Answers
Hi, have you also just doing the bios jumper reset. What make and model is the hard drive their maybe a diagostic to find out wht the problem is. Also does the pc beep at all when you 1st turn it on. Hope this has helped. Thanks
Onlinepc-Fix
lee
Posted on Mar 19, 2008
  • lee webb
    lee webb Mar 22, 2008
    hi, Im glad the problem has been solved, hopefully your have o more problems. If you do let me kow and weresort it out. Thanks for your rating also.
    Onlinepc-Fix
    lee
Asus a8n sli deluxe motherboard diagram manual?
Download page.
http://www.asus.com/Motherboards/AMD_Socket_939/A8NSLI_Deluxe/#download
You must choose an OS like XP. Required, but indifferent. Click on Manual and choose Global link.
Oct 14, 2012 | ASUS A8N-SLI Deluxe Motherboard
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
Does ASUS A8N-SLI DELUXE support fan speed changing?
You can research *********** board and drivers at ASUS.com.
You may find a new BIOS update which controls the fan speeds and temp.
If not, you can find plenty of frreware which will handle *********** board.
Nov 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI Deluxe Its sudenly shut down and not coming back again only fan is working
Try resetting the CMOS, to get the procedures on how it's done on your PC's motherboard, please refer to the image below.
Please reply if this has helped you. Thanks.
Oct 24, 2009 | ASUS A8N-SLI Deluxe Motherboard
Need m2n sli drivers..help?
Your SLI drivers as you mentioned were installed when your chipset drivers were installed. (NVIDIA nForce CK804 Chipset Driver).
If you use 1 PCI-E graphics card the bios will need to be adjusted to [Auto].
Using 2 PCI-E graphics cards you must install the EZ selector card correctly. See page 4-20 section 4.4 Adjust; SLI Configuration. Than see section 4.4.6 in your manual
Open the Asus link below if you need drivers for your M2N-E SLI;
http://www.asus.com/Search.aspx?SearchKey=M2N-E%20SLI
This may seem a bit tricky but its not. First time around the bios settings using SLI graphics cards will appears tough but you'll get it.
Cheers!
Mike
Oct 16, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
A8N-SLI Deluxe asus motherboard wont boot
first you want to make sure
the power supply works, they can stay on for a week then die, then work again , then die
then disconnect the cd rom, and see if it still has the same problem,
next could be the processor , this would be the cheapest part next in line,
processors get warm when they work
if not , you would replace that before motherboard
you can also disconnect the hard drive a while
to make sure there are no config errors
Jul 21, 2009 | ASUS A8N-SLI Deluxe Motherboard
Asus a8n sli premium
From the Asus support site.
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Microsoft Windows 32-bit version operating systems.
If you install Windows 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. Chipsets later than Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture support memory swap function. 2. Windows 64-bit OS which can address more than 4GB memory.
Jan 06, 2009 | ASUS A8N-SLI Deluxe Motherboard
Motherboard problem..
It sounds like the front panel wire has either come loose from the motherboard or is plugged into the wrong spot. Recheck the motherboard to see if the wires are in the right place & not loose. Hope this helps.
Dec 27, 2008 | ASUS A8N-SLI Deluxe Motherboard
Describe your ASUS A8N-SLI Deluxe nVidia video card
Yes, you do. Your board was built with the idea to use 2 graphic boards to get great video
NVIDIA® SLI™technology revolutionizes PC performance by combining multiple PCI Express GPUs in a single and scalable system! Gamers and hardcore enthusiasts know that dual GPUs mean increased, supercharged 3D graphics and performance
Dec 09, 2007 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
What causes ASUS A8N SLI Deluxe chipset fan and RAID failure
Don't bother with another ASUS chipset fan...
just get hold of a Zalman ZM-NB47J Northbridge Cooler. :thumbsup:
i've been running one of these for a month or so because my chipset fan started to rattle, and make more noise than usual crying2.gif
i haven't had any trouble with passive cooling, maximum motherboard temp is 39C.
i run all my drives on the nvidia controller, and it's overclocked a bit too.
plus you'll enjoy the silence :thumbsup:
Oct 27, 2007 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI Motherboard Logo
147 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
