The Haynes manual I have covers the 94-04 Sephia and Spectra, so the procedure would be different. Especially if your Rio is a hatchback. I would suggest you pick-up a Haynes manual that covers your little car. It's quite handy for any repairs you can do yourself. And to educate yourself against less than honest mechanics. I covers interior/body as well as the electricals of the audio system. And everything in between.
each speaker in your car runs the wiring thru an amp. So each spkear has its own amp for the bose system. You can not hook up a none bose radio If you do you will need to run new wires and replace all the speakers. Sorry.
To fill a 94 Kia sephia 5speed tranny you need to take the spedo gear out the big black plastic part sticking out of the top of the tranny close to the firerwall by the bell housing unscrews after you unplug it then you'll need a 10 mm socket and ratchet there's a rubber o ring that will give you a little resistance then you get a funnel and 80w-90 gear oil and your set.
i found one in a haynes book covers sephia and spectra 94 to 04 .i have no idea how to scan this an attach . theres not much to the diagram you have an audio 10A fuse hot in acc or run grn wire .you also have a room fuse 10A hot at all times pnk wire .both are in the i/p fuse block . in the fuse relay box you also have tail lh fuse 10A hot with lights on blu/wht wire the rest is just radio to speakers and antena . wish i could be more help
SOUND LIKE ALTERNATOR NOT CHARGING.CHECK FOR A LOOSE DRIVE BELT.IF DRIVE BELT GOOD AND ALTERNATOR FUSE GOOD AND WIRES NOT LOOSE AND DAMAGED PROBLEM IS FAULTY ALTERNATOR.
pls. be more specific in describing the problem/ door panel means the complete door/ u mean u took off the whole door to install speakers? or just the door trimboard?
the speakers have a neg/positive wire make sure you hooked them up right easiest thing to do is hook up the power and start with two speaker wires once you have sound coming from a speaker label them with masking tape .
1997 Kia Sephia Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/Red Car Radio Ignition Switched 12V+ Wire: Blue/Black Car Radio Ground Wire: Black Car Radio Illumination Wire: Red/Black Car Radio Dimmer Wire: N/A Car Radio Antenna Trigger Wire: N/A Car Radio Amplifier Trigger Wire: N/A Front Speakers Size: 4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Black/Yellow Left Front Speaker Wire (-): Blue/Orange Right Front Speaker Wire (+): Blue/Green Right Front Speaker Wire (-): Light Green Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Green/Red Left Rear Speaker Wire (-): Green/Black Right Rear Speaker Wire (+): Blue/White Right Rear Speaker Wire (-): Red/Blue
