Question about Motorola Talkabout T5600R (7 Channels) 2-Way Radio
Need to replace DVE AC Adapter
Need to replace DVE AC to AC adapter
    Brigadier General:
  • 6,966 Answers
If your desk charger is the version that can accommodate 2 units for simultaneous charging, any wall adapter would do as long as it is rated at 9VAC @ 450mA or higher. Since most wall adapters are DC output, you need to open it and remove the diode(s) and capacitor and connect the output of the secondary straight to the wires. Additionally, you need to get one whose plug will match the jack of the desk charger.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 23, 2008
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
Netbook no power
there are three possible reasons of this issue.
1. Ac adapter
2. Battery
3. Motherboard - you don't want this part to have a problem. It is very expensive.
For this, you need to isolate which part is causing the problem.
1. Remove the battery from your netbook and use the ac adapter only in powering up your computer.
2. If it's not turning on (battery out and only the ac adapter is used), then check your ac adapter for signs of defects. It could be the ac adapter or the motherboard. If you have another ac adapter then you can try it.
3. If the ac adapter works with the computer, then you would need to replace the battery.
Let me know if you have any questions.
David
Jul 13, 2013 | eMachines Computers & Internet
Laptop reboots when ac adapter reattached.
There are three parts in the computer that you need to check.
1. Ac Adapter - it could be defective.
2. Battery - it could be that the battery and ac adapter won't work together because the battery has gone bad. We cannot tell without checking that.
3. Motherboard - it could be that the motherboard's power port is defective.
Do the following so that you can isolate the problem.
1. Remove the battery and use the Ac Adapter only and turn on your computer. If it turns on without any problem, then replace your battery.
2. If the computer still reboots with the ac adapter plugged in (no battery), then replace the ac adapter. or try using a different ac adapter which is compatible with your computer and check if it produces the same problem. If the other adapter produces the same problem, then it's in your motherboard and you need to get it fixed by a technician.
David
Jun 09, 2013 | Computers & Internet
I can't get my dell inspiron to power on. I will charge the battery using the wall charger but will not come on. What can I try?
Try this if will help.
Remove battery and unplug the ac adapter from laptop.
Without the power sources hold down the power button for 10 seconds.
Check the ac adapter from wall power socket if ac adapter LED is ON.
Plug back in the ac adapter to laptop then check the LED from the ac adapter if it stayed on.
If ac adapter LED turned off right after you plug in the ac adapter to laptop then you need to replace the ac adapter, motherboard and power daughter board.
Hold down the D key then Press Power Button once. Check if color display will appear in the screen.
if the ac adapter stays on you and still no power indicator from the laptop you need to replace motherboard and power daughter board.
Hope this helps.
Jun 02, 2011 | Dell Inspiron 6000 Notebook
Have a dell inspiron with original ac adapter and battery. i get error message saying that the AC adapter cannot be determined is not recognized by dell and need a dell 65W AC adapter. I have the...
The adapter could be faulty or has failed slightly and is below the operating limits. This means you probably need to replace the power adapter.
Nov 01, 2010 | Dell Inspiron 1501 Notebook
Cannot get my computer to turn on
remove all external peripherals. remove laptop battery. remove ac adapter.
plug ac adapter to wall power socket without the laptop connected check if the ac adapter led will stays on. if yes then connect it to the laptop and check if the ac adapter led turns off. if yes motherboard laptop has problems and need to be replaced.
if ac adapter led stays off without connecting laptop, try different wall power socket, if still ac adapter led is off then replace the ac adapter.
if ac adapter has light stays on then connected to laptop but laptop cannot even power up even the ac adapter led is on then laptop motherboard needs to be replace.
Dec 09, 2009 | Dell Studio 15 Laptop
AC Adapter
Ususally the model number s located in the battery compartment or on the bottom of the player.  Check ebay for an adapter.  Usually you can find an adapter that is universal for all durabrand dvd players.
Jan 06, 2009 | Durabrand PDV-709
Sony Vaio ac adapter submerged
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Thanks
Mar 23, 2008 | Sony VAIO VGN-FS630/W Notebook
Motorola Talkabout T5600R (7 Channels) 2-Way Radio Logo
1,009 people viewed this question
Top Motorola Radio Communications Experts
Steve
Jose Ma DM.
Jose Ma DM.
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
