Question about Brother DCP-7020 All-In-One Laser Printer
Brother 7020 printer "fuser error"
Brother 7020 Printer won't print. Says, "fuser error. Turn machine off for 10 mins."
    Problem Solver:
  • 12 Answers
The fuser has failed and needs to be replaced. If it is still under warranty Brother may cover it. If not you will have to take it to a Brother Authorized service center. It may be possible to find a used one on Ebay, even if its just for parts. Some of these smaller machines require extensive dissassembly to replace the fuser and shouldn't be attempted by a novice.
Posted on Mar 27, 2008
SOURCE:
Machine error 50
On a Brother printer Error 50 typically means that the Fuser is malfunctioning.
Turn the printer off for about 5 minutes. Then turn the printer back on and wait for about 10 minutes. If after 10 minutes the printer doe not recover, you will need to replace the fuser unit. May be more economical to replace the whole printer.
Jun 30, 2014 | Brother Dcp-J125 Compact A4 Colour Inkjet...
I have a Brother DCP 8020 Multi printer. Im getting machine error code A6. After replacing the fuser
This is what is written in my service manual for Error Code A6:
Error code 6A
Print Unable 6A
Turn the power off and then back on again.
Fuser unit failure (The side thermistor does not detect 60degreesC within the specified time.)
Dec 05, 2012 | Brother DCP-8020 Laser Printer
I am getting several black lines in scanned and copied documents of my DCP 7020 Thanks
Check the print document to see if the ink rub of easily,if so this mean the fuser cartridge need to be change.Turn off the printer and wait until it is cool before changing the fuser cartridge because the fuser get very hot when ever the printer is in use.
Open the fuser cartridge door. On most printers this door will be either on the left-hand side of the printer or in the back. Consult your owner's manual for the exact location. Flip down the clips that hold the cartridge in place, then grasp the handle and pull it out of the printer.
Push the new fuser cartridge in until it snaps into place, then flip the clips up to lock it in place. Close the fuser cover door.
Open the toner cartridge door and remove the toner cartridge. On most laser printers the toner cartridge is located either in the front of the printer or on the right-hand side.
Vacuum underneath the toner cartridge to remove all paper dust and toner residue. This debris has a tendency to build up and cause streaks and stains on the paper.
Wipe the interior of the printer with a soft cloth to remove any remaining debris that could cause problems with print quality. Continue cleaning the printer until all debris is removed.
Purchase a set of laser printer cleaning sheets, and load one or two in the paper tray. Print to those sheets of paper to clean the paper path. These sheets are slightly sticky, and they are designed to remove dirt and debris from the paper path.
You should also clean the print drum and the corona wires.
Aug 30, 2010 | Brother DCP-7020 All-In-One Laser Printer
Machine error 6D
I looked that error "6D" and could not find anything.
Although there is a error 6E that denotes a hardware problem with the machine.
Mar 12, 2010 | Brother MFC-8840D All-In-One Laser Printer
Double printing addresses on envelopes
You need to make sure you set up for envelopes in printing preferences as this makes the fuser a little hotter. If all is set up properly you need a shop to adjust the fuser temperature. The thick envelopes require more heat to bond the toner properly.
Feb 05, 2010 | Brother DCP-7020 All-In-One Laser Printer
Error 41 brother all in one :Performed Print Quality Check Sheet $ times. The test sheets became closer and closer to being 100% correct, then error 41 pops up
Machine error 41 is "defective print head".Try to turn off the printer and wait 10 min.Then turn on, if the error continue showing your printer need service.
Oct 13, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother 7020 Fuser does not warm up
dcp-7020 fail to warm - how do i reset if i turned off and on already and waited 10 minutes
Dec 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
1,046 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
