D2d recovery i cannot run d2d recovery from aspire 5610 4648. I have tried to press alt+F10 during boot up screen, but it doesn't work. Also i couldn't find acer erecovery management in acer empowering management. Any idea how to run d2d recovery, or how to copy from its hidden partition? i need get the Acer Aspire 5610 Vista Windows Recovery CD Restore Disk!!!
  • sqteck Mar 02, 2009
    ASPIRE 5930 with VISTA HOME PREMIUM - I have installed XP+SP2 on c: with format in NTFS (it was FAT) (other partition I have leaved without change) but there is so troubles with XP drivers than I have to return to VISTA. I have been trying to change MBR with help of KNOPIX and with PTEDIT32 and "mbrwrdos.exe install rtmbr.bin" but in both cases there is no rtmbr.bin file on this hidden partition. Probably should to be mbrwrwin.exe - oK I will try but why F3 (find file function) did not found "rtmbr.bin" file (of course the partition is already not hidden after PTEDEIT32) ?
  • magdyarabcon May 11, 2010
    i cannot run d2d recovery from aspire 5720. I have tried to press alt+F10 during boot up screen, but it doesn't work. Also i couldn't find acer erecovery management in acer empowering management. Any idea how to run d2d recovery, or how to copy from its hidden partition?
    i need get the Acer Aspire 5720 Vista Windows Recovery CD Restore Disk!!!
    Genius:
  • 1,011 Answers
Hello Sir / Madam,
Many Acer systems come with the ability to press ALT+F10 to kick off the Acer Recovery applications from a special hidden recovery partition. Sometimes this won’t work and there can be a number of reasons.
1. D2D Recovery is “Disabled” in the BIOS (Main menu).
FIX: Enabled it and try pressing ALT+F10 again as the computer boots.
2. The Acer hidden recovery partition (PQSERVICE) has been removed or damaged. If the disk drive is a replacement drive then you won’t have this partition.
FIX: Unless you have previously imaged the PQSERVICE partition it will not be possible to use D2D recovery. You will need to restore from the Acer Recovery CD/DVD.
3. You have converted the FAT32 partition on the hard drives into NTFS. Acer D2D recovery won’t be available if you perform this conversion. Ironic that NTFS is a more desirable disk format to use but Acer won’t support this in their systems!
FIX: Restore your system from the recovery CD/DVD media.
4. The special Acer Master Boot Record (MBR) has become corrupt or has been overwritten with an non Acer MBR. As long as the PQSERVICE partition is there or you can get your hands on a couple of Acer service files for your model, then you can remake the special Acer MBR. Let’s cover how this is done.
  1. Disable D2D recovery in the BIOS. Can be found in the “Main” menu section. Save the BIOS settings and exit.
  2. Log into Windows with an “administrator” level account.
  3. Download ParTEDIT32.ZIP (registration required for download).
  4. Extract PTEDIT32.EXE from the zip archive and run it.
  5. Identify the PQSERVICE partition by its type or size. It is likely to be 12 or another custom value and is likely to be reasonably small in comparison to the other normal partitions - see the example below from a working factory default Acer. Click the Link below see the image full size. http://www.roundtripsolutions.com/blog/wp-content/uploads/
  6. 2007/10/AcerDiskRecoveryBroken_F031/hidden.jpg
    Change the type to “07′ (Installable File System NTFS, HPFS) and “Save Changes”.
  7. Reboot the computer and login with an “administrator” level account.
  8. You should then be able to open up a command prompt and navigate to the PQSERVICE drive.
  9. Enter the following command at the command prompt:
    - You may have to search for these files and change into the relevant directory.
    Note: This step writes the Acer MBR, with mbrwrdos.exe and rtmbr.bin being the special service files.
  10. Close the command prompt window and reboot.
  11. Go into the BIOS again and enable D2D Recovery. Save the BIOS settings and exit.
  12. ALT+F10 should now start Acer Recovery as the computer starts.
  13. The Acer MBR ensures the PQSERVICE partition is hidden therefore there is no need to reset the partition type back to 07 - well there shouldn’t be if all has gone well. If you need to manually reset it then run PTEDIT32.EXE again, set the partition to 12, or whatever the original value was, and save the changes to complete the process. Reboot and it should now be hidden.
If Windows is unbootable, due to whatever issue, you can always use the Ultimate Boot CD for Windows (UBCD4Win) along with a copy of PTEDIT32.EXE to achieve the same results. Likewise, use UBCD4Win along with PTEDIT32.EXE if the PQSERVICE partition is being changed back to a hidden one by the existing MBR. We’ll leave that as an exercise for those who need to do it! It has been pointed out in the comments that UBCD4Win already has an application that will do partition maintenance, so checkout TestDisc if you go down that road.
If this is a new drive or someone has completely wiped the drive, including the hidden partitions, it may be necessary to use partitioning software to recreate the partitions that the Acer Recovery system is expecting! You’ll also need to restore an image of the recovery partition from a previously made backup, so it is worth making that backup image straight away while the laptop is still new and shiny, and certainly well in advance of any problem.
A final word or two of caution: take great caution when playing around with partitions on an Acer system… you have been warned… and remember to make the backup media disks as soon as you fire the computer up for the first time!
Thanks
Good Luck
Don't forget to rate the Solution!!!!!!!!
Posted on Mar 20, 2008
If you have a system running Vista or Vista x64 and/or Windows 7 or Windows 7 x64, Acer's LOVE to mess up the MBR (Master Boot Record) when you change the OS on the drive or if you install Linux and it goes badly, or you upgrade from Windows XP to Vista... heres how to fix it. Get a copy of HiRens boot cd and boot to it. if your PQSERVICE (Recovery) partition is messed up, follow the instructions above except the drive should be an NTFS filesystem, type: 0x27 (27h). you can use Acronis Disk Director on HiRens to fix this up, and it should be on Disk 1, Partition 1 (the very first partition on the disk), Non-Active status. after the partition is in the correct space and the flags are set correctly, you need to use the utility eXtended FDisk on HiRens, and place a bootloader on the disk...Disk 0, Partition 0 (the first partition, the recovery partition). this will now make your Alt+F10 work... go ahead, reboot your machine to the first Harddrive, it should boot the recovery, the same as though you were to have pressed Alt+F10, only you haven't. now we can get rid of that pesky boot chooser we added, for this we use the utility MBR Tool. Be very careful with this tool, it can cause some real damage if used incorrectly. Choose option 4, you want to play with the MBR, then choose option 9 to write/refresh the bootcode and it will ask you which disk, choose 0, and then choose Source type O for Original. It will follow with a status message elling you it has completed and to press any key. then 'ESC' your way back to the R:\ prompt. Then reboot your system without the HiRens CD and do your Alt+F10 thing and everything should be back exactly as it was from the factory. NOTE: make your active system partition before you intend to recover your machine after correcting the D2D mode, make the partition the size you will need...Usually 75Gig for Vista and 100ish for Win7, that usually suffices with most users, even those that are software heavy, because when you recover to factory it doesn't create or modify partitions, it uses the first it finds beyond the recovery regardless of size or whats in it, and assumes it to be the 'C' drive;)
Posted on Jun 07, 2009
Thanks for the utility
Posted on Feb 14, 2009
Registratieproblemen
Posted on Nov 22, 2010
I have this problem
Posted on Mar 24, 2009
Problem easy solved with aspire 5720. mbrwrdos.exe was not available, worked with mbrwrwin.exe. Very helpfull, thx
Posted on Sep 02, 2008
Acer Aspire 5920g laptop My computer suddenly crashed during an update coming up with a blue screen. Since then I have tried to use the recovery disks. After successfully loading and showing "windows...
Hi
it may be worth trying this
power up and press the Alt+F10 as soon as possible and this may take you into the factory restore option
where you should have about 2 different options of recovery
just follow the on screen instructions
i hope you can get it sorted
Jun 23, 2011 | Acer Computers & Internet
Factory reset for Aspire one without disk and alt + F10 doesnt work
The disk-to-disk recovery may be disabled preventing the Alt + F10 key sequence running eRecovery. To enable disk-to-disk recovery, you must do the following... (do not have an external monitor attached)
1. activate the BIOS utility by pressing F2 during Power On System Test (while Acer logo displayed)
2. select Main from the categories listed at the top of the screen
3. find D2D Recovery at the bottom of the screen and use F5 and F6 keys to set this value to Enabled
4. exit the BIOS utility and save changes.
The system will reboot.
5. while the Acer logo is showing, press the Alt key and the F10 key at the same time repeatedly
6. wait as Acer eRecovery starts up then follow onscreen instructions to perform system recovery.
Alternatively to the above, if Windows can be accessed, the recovery can be done by launching Acer eRecovery Management by running the program from the Acer Empowering Technology program group in the Start menu.
Mar 22, 2011 | Acer Aspire One PC Notebook
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have 1recovery **** named aspire 5610 dvd2 should i have a dvd1 disk also
go to http://www.sysresccd.org/Download
download the iso and burn it to a cd.
boot your computer with it
read the explanations coming up on the screen and when you see that you can choose how to start, type "wizard"
choose the top choice (auto)
when it starts right click on the desktop and start GPARTED.
one of the discs will be marked as "boot"
right click the disc called "recovery" (or the one that is not marked as boot).
choose manage flags
set it to Boot.
press apply on top (not always needed tho)
in the left picture (the one that opened from the start)
type reboot
remove the cd when you see the acer logo again.
the acer recovery manger should start.
May 29, 2009 | Acer Aspire 5610-4648 Notebook
System recovery not working.
hello try this website http://www.thinktechno.com/2008/02/09/how-to-fix-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
lets try this first and if it don't work we will try something else
just copy and paste in your address barr
hope this helps bob
Mar 24, 2009 | Acer Aspire 9300-3716 Notebook
D2d recovery
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Good luck and Merry Christams
Dec 24, 2008 | Acer Aspire 5630 Notebook
Erecovery
Check that it is enabled in the bios
Press F2 when you boot and go into bios, make sure that D2D recovery is enabled. Then save the changes and exit, to run the recovery program you need to press Alt and tap F10 on boot when the manufacturers screen appears.
I hope this helps
Nov 14, 2008 | Acer Aspire 5315 Notebook
D2d recovery
you can not use erecovery and d2d if your don't have the hidden d21 partition on your harddisk. and since you have replaced your harddisk you don't have it anymore.
mail to compurepair and see if he can fix it..
rate me if you want.
CS.
Apr 08, 2008 | Acer Aspire 5630 Notebook
D2d recovery
Is the d2d erecovery function enabled in the bios?
To check, activate the BIOS utility, press <F2> during the POST; while the notebook PC logo is being displayed.
To enable D2D recovery ard disk recovery), select Main from the categories listed at the top of the screen.
Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled.
That should allow you to use the F10 function key to activate D2D.
* Note: D2D e-recovery is not in Acer Empowering Management.
AEM is a power management utility that supports ACPI (advanced configuration and power interface) which allows for maximum power conservation and maximum performance. (Managed by the windows OS)
Jan 04, 2008 | Computers & Internet
Computers & Internet Logo
23,748 people viewed this question
David Payne
David Payne
