Question about Philips Magnavox 51MP392H Rear Projection Television
Arch on top and bottom of tv
My 51 inch tv has a arch on the top and bottom is there an adjustment i can get to fix this
  • eddie500 Mar 21, 2008
    what part would i need replaced,i talked to a repair guy he said it was a senser is this right ,is there an adjustment inside this tv like a vertical hold ?
  • 8,596 Answers
You can try adjusting the convergence manually, but this is not a good symptom for your TV to have.
Look at this Quick Start Guide, p. 7:
http://www.p4c.philips.com/files/5/51mp392h_17/51mp392h_17_qsg_aen.pdf
Posted on Mar 20, 2008
Faint red lines in a curved arch like pattern
For this problem, what you have to do is here I found this solution: Right below your speakers on the right and left side are tabs. Pull out the tabs and remove the screw on eachside. Once that is done remove the speaker cover and you will see a fiber board cover in the middle of the tv, there will most likley be twist ties holding some wires, to make it easier to work remove the ties. Now remove the screws on the fiber board and pull it off. You should see 3 adjustments on the top for focus, do not touch those. Below the focus adjustments on the bottom is the blue, red, and green adjustments (they should be labeled). All you have to do is turn adjustment screw slightly to the left(or counter clockwise) and it should clear right up. That should do the trick, Hope this is helpful. Please dont forget your rating.
Jan 26, 2008 | Sony KP-51WS500 51" Rear Projection...
My display is arched on the top and bottom of display on my sony kp61hs10. Wanted to know a solution to fix this issue.
Convergence output ICs in your tv got defective and causing arched on top/bottom of screen.
Convergence output ICs will be replaced to fix tv problem. There is Convergence Repair Kit available along with photo instructions to fix tv problem and you can attempt to repair tv if you have little experience for that to understand those instructions. Or local tv repair shop will help you to fix the tv problem.
Jul 19, 2010 | Sony KP-61HS10 61" Rear Projection...
From about 4 inches down from the top of the tv and from the center to the left corner is red and green and the corners on the bottom of the tv are also arched but not as bad
this is a vartical non linarity folt .
chech vartical stage capaciter 470umf/63v 4.7um/50v 1000/50v
0.47um/63v Replace and first svr.menu to set vartical linyarity adj.
set V- hight is sum down sum 1" or 2 " after the set vartical linyarity V-line. set up to down and check the pictur. if not then Replce capaciter.
Oct 04, 2009 | Hitachi 51F500 51" Rear Projection...
Magnavox convergence arch bottom of tv
you have a problem on your convergence driver board,either a leaky capacitor, resistor increased in value or a STK ic going bad
Mar 21, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
Help- picture
yes,this can be fixed for $ 280.00 - $350.00 depends on your area,you need to replace STK-392-110s both stks then do complete realinement of convergence. set fixed!!!!
Oct 17, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Red and Green Vertical Arches
CHECK ANY MAGNETIC MATERIALS ON THE CORNER OF THE TV.IT HAPPENS DUE TO MAGNETIC MATERIALS ONLY. SUPPOSE IF IT IS THERE KEEP AWAY FROM THE TV. AND THEN GO TO THE MENU OPTIONS AND SET AUTO DEGAUSSER ON.
Apr 23, 2007 | Philips 32PT8302 32" TV
Green arcs from bottom up with darkest one at bottom on dark screens
there is a way to get rid of the lines, you need to enter a code from your remote to access a hidden menu. From there you can adjust the lasers in the tv(green lines)I beleive it is very sensitive though, if done wrong can reck the tv. Not sure of the code or directions on how to exactly adjust the lasers, actually looking for them my self. Hope i was some help though!
Jan 22, 2007 | Sony KP-51HW40 51" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
