Question about Toshiba TDP-S8 Multimedia Projector
TDP-S8 Did you find the problem with your projector? Mine is having the same problem with powering up, then shutting down after about 5 seconds, blinking yellow light, and that's it. Thanks. [email protected] Bill
  • 1 more comment
  • Anonymous Jan 14, 2009
    How do you reset the lamp timer
  • hnkurtiz Jan 29, 2009
    Unbelievable! This has been going for a while at my house too. We find that if we dont use the projector for a few days it will turn back on but then once you turn it off you can't start it back for a few days. I don't want a every-other-day projector, I want one I can use when I want to use it. Guess we have to buy a new one!
  • stevehof May 11, 2010
    I've had a similar issue, but where 2 of the caps on the main board fell off!! I've put them back on but still to no avail, i'll try your method of replacing that cap, but if that fails, would you mind sending the service-manual through to me, steve at bhr2.za.net. I'm a student and a bit poor. Thanks.
The main problem is the power supply. In detail, the output capacitor of the power supply causes the problem. I guess, Toshiba or Lite ON didn't consider the aging effect of the output capacitor. You should replace the output capacitor to fix the problem. (In some sites, they recommend to replace the power supply, but don't do that. The new power supply costs over $200 and the capacitor will be less than 50cents.) If you disassemble TDP-S8, in the power supply, you can find the electrolytic capacitor 3300uF/10V. You should replace this with any electrolytic capacitor with the range of 2000uF~4000uF/10~16V. You can download the service manual from some websites (I've paid $5 for this) then you can disassemble the projector. Of course, you need to do soldering to replace the capacitor. I've fixed this problem yesterday and it took about 4 hours for me. Good Luck~~!!
Posted on Jan 15, 2009
Fixed! Its a very delicate operation but I replaced the capacitor as described. Don't forget to put back the lamp door cover, it toggles a switch that enables the power supply. It took me a while to figure out why the fix was not working and the darn door was the reason!
Some more info: This power supply generates 3.3, 5, and 13V plus a high voltage of 350V. Other than the lamp-cover-switch the power is always on and could be replaced by an external supply if you cannot fix any of the 4 voltages.
BTW, this made me look at other electronics that have not been working. All my blown UPSs have blown capacitors!! All my blown computer power supplies also have blown capacitors!! This is a big problem.
Posted on May 28, 2009
Reset the lamp timer
Posted on Mar 30, 2008
SOURCE:
Cant remember password for my toshiba tdp s8
I had a projector toshiba TDP-S8 but it is used when i turned it on it required a password what can I do
thank you
Nov 09, 2009 | Toshiba TDP-S8 Multimedia Projector
I have a toshiba TDP-S8 projector up until about a week ago it was fine but now when i try to turn it on either by remote or button on projector the yellow power light disappears then reappears about 5...
Check the color wheel if it is not turning when you hit the power button (light should flash) you have 1 or 2 loose caps on the bottom of the main board behind the audio input try to resolder them with low heat iron these are smt caps and very hard work on if you have not worked on this kind of job take it to a expert
good luck! ps make sure you glue them down
if you do get them to work to prevent a reocurance.
OR you have a power supply issue which
should be a swolen 3300 mf 10 volt cap
in the main power supply.
Aug 24, 2009 | Toshiba TDP-S8 Multimedia Projector
The projector comes on, lights up but then shuts off after 30 seconds
My TDP-T9 had the same symptoms. A 3300uF 10V electrolytic cap in the power supply (Liteon) unit was domed up, so I replaced it with a high-spec 2200uF 16V cap costing three dollars. The re-flow solder on the board was damn hard to melt though, needed 400°C setting on the soldering iron.
Jul 17, 2009 | Toshiba TDP-S8 Multimedia Projector
It shows no signal
Toshiba TDP-S8 projector cannot communicate from my laptop, it shows no signal. how can i fix it? thank you so much...
Feb 19, 2009 | Toshiba TDP-S8 Multimedia Projector
TDP-S8 only run for 20 sec.
Possible filter problem or sensor related to over heat. Might also be a bad bulb or worn out bulb.
Leaning more towards bulb replacement.
Dec 08, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba Lamp Reset - How?
Not positive, but I would assume the same as my Toshiba.
With the on, input, and menu buttons held down, insert the power cable.
Hope this helps, NGK
Aug 14, 2008 | Toshiba TDP-S8 Multimedia Projector
Standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
Jul 15, 2008 | Toshiba TDP-S8 Multimedia Projector
No Power to My Toshiba TDP-S8
Console and mainboard not communicating. avalontc.com
Jun 05, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-S8 Multimedia Projector Logo
3,213 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
