Question about Mitsubishi WS-65857 65" Rear Projection Television
There doesn't seem to be any break
Hey Slinte, I read your post and I appreciate it. The first thing I did was go check on the blinks. I watched about 5 more times and I can't see any kind of break or delay between blinks. It just powers down as if you had pulled the plug on it and then pauses for 3-5 seconds and then does three rapid, evenly spaced blinks. If you have any other thoughts on it or if you have a digital copy of the manual and think it might help me please let me know on this page or by my E-mail Thanks.
  • Mitsubishi Master
  • 8,617 Answers
I have a set of schematics that I couls send you if you'd like. I dont have the service manual but the site that I work for as a support tech has the full service manual for the entire V17 series which covers your model for 17.99 if you would like the service manual I moved it to their front page just in case. They will email it and they also offer free support to help diagnose the problem and locate parts to anyone that gets a service manual.Heres the link in case you want one.
Posted on Mar 19, 2008
Projector doesn't show image.
Projectors sometimes give error codes to help you figure out what might be wrong with it. Read the user manual for your projector if you have it, or look for the manual online. See if it has a "troubleshooting" or "maintenance" section. Projectors often give error codes in the form of blinking lights. The color of the lights and their blinking pattern help you to diagnose the problem. Without knowing the make/model of your printer, that's my best suggestion.
Dec 07, 2015 | Office Equipment & Supplies
Hello jsrock516, I've followed your posting step by step. Readings were as...
This advice is for all ELECTRIC Dryers that have a "No Heat" problem.
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
I hope this information is helpful to you. If you need further assistance, please go to my profile at: and use the "Ask Me" feature for a quicker repsonse to your questions/comments.
on Dec 30, 2008 | Kenmore 62602 Electric Dryer
My dad has a status xl6 mobility scooter and while on his travels it just gradually slowed down then stopped, when you press throttle or reverse it doesn't even try to move just bleeps until you turn...
Yes,there are set things to check & series of beeps etc mean certain things.This should help you get your dad back mobile.Download as a PDF File:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 .Something to bear in mind,if you do anything on a scooter or wheelchair,then take it to a repair place.A lot will not touch it,so stay on top if you are taking the job on.Take a photo of everything you do on your mobile,then you can relay back to things.Also check when taking things apart,it can be easy to break a wire in the tilller mainly.I hope i have helped you.Colin
Jul 16, 2013 | Health & Beauty
I just bought an adidas ADH4033. I have read through the manual thousands of times and have figured out how to change the hours on the watch but still cannot change the minutes, date, 12/24 hour, or any...
this might help. press and hold top right button to change to T1 or time 1. press and hold top left button and u will see ' light on/off' on display. press bottom left button to set chime. press again watch will show 24hr/ 12hr and current time set on watch. 12hr/24hr should be blinking. press top right button to change to preferred hour. press bottom left button to navigate to hour, min,sec use right buttons to select numbers.
Aug 27, 2011 | Watches
I have a Duo 1025 for women. The watch doesn't seem to detect the chest strap transmitter. It was working alright when I bought it and tried using it a few times. But now the watch is not giving a...
Make sure the battery is placed underneath the small copper clip (positive lead) inside, else the circuit isn't complete. It's pretty easy to clothes the battery casing with it above the lead and not even notice it.
Jul 26, 2011 | Sportline 1025 Duo Heart Rate Monitor...
My chevy aveo 2006 model, after having problem with my alternator and replacing it with a new one, the engine lamp suddenly blinked. engine & other power sounds ok. What seem to be the problem
your engine lamp could have blinked for many reasons, as far as your alternator and battery system, make sure the battery is fully charged, when it is, you should get a reading of 12.4 volts, checking it with a volt meter doesn't necessarily mean thats charged fully as far as amps, you should have your battery LOAD tested to make sure it can fully charge and hold that charge, once its charged the alternator should keep it that way , if you test the posts with a meter while the motor is running you should get a reading of anywhere between 13.5 to 14.5 volts, when checking the battery , make sure all connections are clean and tight
Jul 18, 2011 | 2005 Chevrolet Aveo
Try It's kinda' laggy, but it works ok sometimes.
Apr 20, 2010 | YouTube Videos
Mitsubishi WS 48511 Blinking Green Power Light
Your model will have two picos mounted on the same board with the 7 capacitors they will look like resistors without the color bands they will be F9B01 and F9B00 check them for continuity.
Jul 27, 2008 | Mitsubishi WS48511 48" Rear Projection...
Redish Pink screen??
the CRT is the picture tube. If you cant control the red alot of times its the picture tube (CRT) that has shorted causing the screen to take on the dominant color of the affected tube.
Mar 25, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Casio watch
Get the code from the back of your watch and try going to the casio site for the manual. I was reminded of this by Noggins posts No if I could only figure out how to change the battery
Jun 20, 2007 | Casio Technowear CMD40B-1T Wrist Watch
Mitsubishi WS-65857 65" Rear Projection Television Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
