Question about Kenmore 24032\24036 Top Load Washer
Kenmore series 70 model 10--------
The washer when in the spin cycle is whining as if there is a bearing worn or some type of friction or ot could be the motor. So far the operation had not been affected. Can you tell me what you may think that noise is coming from?
David
[email protected]
    President:
  • Kenmore Master
  • 2,651 Answers
Possibly somthing in the pump or the bearing in the pump has gone bad, hte pump is clipped to the front of the motor dont diconnect the hoses but unclip it and move outh te way. see of if its quite now if so you know you have a bad pump
Posted on Mar 19, 2008
SOURCE:
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Kenmore Series 70 washer keeps spinning when you open the lid, is this the correct operation? Also, the washer is always moving around when in the spinning cycle, is something worn out or what?
If the machine keeps spinning if the lid is open then the lid switch has failed. This is the safety device that prevents injury from people reaching in and getting hurt when the machine is in operation.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 04, 2012 | Kenmore Washing Machines
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 series
hello mam for two years you have not used the washer so the bearings may worned out so lubricate the bearings and check the belt should not have any cracks on it,and after lubricating run the machine without loading clothes the observe the noise if seems to be same then change the bearing to change the bearing call the engineer.
Sep 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aug 27, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
70 series kenmore washer
just pull it off - it's friction - fitted.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
37 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
