Go to menu then setup if you do not see convergence listed in menu then you have blow Fuse FL231. Located next to FBT flyback transfomer on right side there is 3 fuses in a roll they will look like small rectrangler caps but are Fuses.06 amp
If by 'triple image' you mean three seperate images with slightly distorted colors, it may be that your picture source has a resolution enabled that your set is not capable of. Make sure you only have enabled resolutions the set can display (480i, 480p, 720i, 1080i etc.)
