Question about IBM 3500 Typewriter
Wheelwrite 10 stuck in the middle
When I turn on my IBM wheelwriter 10, it goes through the start up cycle and then returns to the middle, like there is a margin there, I have tried to clear the margins, but it doesn't seem to work, The backspace will not work as well. If I turn it off and then back on, I can get the backspace to work, but only to the middle again. What could this be?
  • IBM Master
  • 3,594 Answers
It sounds like the left margin is set in the middle of the page, return to the stopping place, press margin release then backspace to the place where you wany the left margin and press l. margin key.
If that dosen't do it remove the batteries and unplug the machine for a minute or two all settings will go to defalt. CAUTION ALL THE MEMORY WILL BE CLEARED!!!
DickyO
Posted on Mar 19, 2008
SOURCE:
What causes the problem when the letter l is typed and it will not space on an IBM Wheelwrite 6
You language button is activated, depress code and hold it down then press the lang button. Usually is the L button.
Jan 21, 2016 | IBM Wheelwriter 6 Typewriter
IBM Wheelwrite 1000 by LEXMARK auto return not working
is auto return turned on and is the right margin properly set
Jul 09, 2014 | Lexmark Wheelwriter 1000 Typewriter
Lexmark wheelwrite 1000 typewriter- print solenoid printer not striking paper
the solenoid plunger makes contact with the print hammer. there is a nylon cap on the contact end of the plunger that goes bad and needs to be replaced not an easy job unless you have done it a few times
Jun 17, 2014 | Lexmark Wheelwriter 1000 Typewriter
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
DickyO
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
IBM Wheelwriter 6781 won't perform a full carriage
Spray some WD40 on the silver shaft that the carrier slides on. If this doesn't work Spray some on the carrier motor bearings, located under the case R. rear corner. You can access the front one from 9inside the rear you will have to fish the straw thru the case.
DickyO
Aug 04, 2011 | IBM Office Equipment & Supplies
IBM Wheelwrite 70 Series II - where is on/off switch?!
The O/O switch is on the top L. rear corner, it is red or white.
DickyO
Nov 08, 2010 | Lexmark Wheelwriter 1000 Typewriter
IBM LEXMARK WHEELWRITE 5 TYPEWRITE NOT TYPING
Be sure the print wheel is properly installed and that there is no debris in the P/W area. otherwise you'll need a tech.
DickyO
May 19, 2010 | IBM Wheelwriter 6 Typewriter
Where do I find where the batteries go on ibm wheelwrite 6
Depending on the age they are either just beyond the keyboard on the right or left side, open the cover and look down just past the keyboard. 2 0r 3 "AA" batteries.
DickyO
Apr 08, 2010 | Lexmark Wheelwriter 1000 Typewriter
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
IBM 3500 Typewriter Logo
190 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
