Question about Crosley CR248 Turntable
Display THe display went haywire and I can't tell what is going on - not readable is there any to do a reset on this machine?
  • alk45 Jun 01, 2008
    I have a Crosley CR247. The display went dead and I cannot tell what is
    going on when I try to record. Is there a soltion to this problem?
    ALK
    Scholar:
  • 157 Answers
Hello stretchv(?St.Francis) & alk45. this appears as a mutual problem. I "NEED MORE INPUT" . Does the unit peform any functions? Does a PWR indicator lightup? If you got the GUTS open the unit up CAREFULLY and unplug the display PCbd, clean the contact surfaces with a #2 pencil eraser or if it uses a ribbon cable reseat the plugs carefully. Oh yes, make sure it is uplugged form the AC power BEFORE you put a screw driver to it. Good Luck.
Posted on Sep 20, 2008
Problems with programme (washing cycle) how to reset
Her indoors did this on a regular basis, I just held in the power button until the display flashed and it reset itself. Good luck
Jun 30, 2014 | Zanussi ZWD12270 Front Load Washer / Dryer
Gages went haywire car won't start
Check all your fuses. Had a similar problem with brothers truck. Found a master fuse hiding under the battery causing problem.
Apr 28, 2014 | 2000 Subaru Outback
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
2005 nissanmaxima fuel gauge went haywire
the gauge connections must be loose or adrift
Jul 05, 2010 | 2005 Nissan Maxima
The screen on my Apple Powerbook G4 goes dim and sometimes out.
How long before it goes dim?
Does it start strong, then dims right away?
Feb 27, 2009 | Apple iMac G4 Desktop
Display resloution
if it is your desktop resalution go to display properties
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 10, 2008 | Acer Aspire 5002WLMi Notebook
Canon Laser Class 9000 Super G3 Plain Paper Fax
I bought a Canon FaxPhone Super G3. I was told I could set the machine so that whe I send a fax from the machine, the machine can send a copy to an e-fax number. If possible, can you please explain how to do this?
Thanks,
Raul
Jan 01, 2008 | Office Equipment & Supplies
Crosley CR248 Turntable Logo
132 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
