Macro Can I create a command which will automatically run Macro periodically? I know how to build a Macro which will update the sheets in a worksheet and my boss askes me to find out whether I can have another command that will call the Macro to run periodically. Thanks a lot.
    Problem Solver:
  • 11 Answers
Sure,
Private Sub Workbook_Open()
Application.OnTime TimeValue("15:00:00"), "MyMacro"
End Sub
This will run the Procedure MyMacro at 15:00 each day.
Posted on Mar 19, 2008
How to create macro button in microsoft excel 2007 because
well follow the steps below to get your job done:
To create an option button in Microsoft Office Excel 2007, make sure that you add Option Button (form control) to the Quick Access Toolbar. To do this, follow these steps:
  1. Click the Microsoft Office Button, and then click Excel Options.
  2. Click the Customize category, select All Commands in the Choose commands from list, select Option Button (form control), and then click OK.
To create an option button and to assign a macro to it, follow these steps:
  1. In Excel 2003 and in earlier versions of Excel, click Option Button on the Forms toolbar, and then draw the outline of the button on the sheet.
    In Excel 2007, click Option Button (form control) on the Quick Access Toolbar, and then draw the outline of the button on the sheet.
  2. Select any cell in the worksheet.
  3. In versions of Excel that are for Microsoft Windows, right-click the option button, and then click Assign Macro.
    In versions of Excel that are for Macintosh, press COMMAND while you click or press CTRL while you click, depending on your operating system version. Then, click Assign Macro.
  4. In the Assign Macro dialog box, click the name of the macro that you want to assign to the option button, and then click OK.
When you click the option button, the macro will run.
good luck ...:-)
Apr 08, 2010 | Microsoft Office Excel 2007
Closing Worksheet on executing Hyperlink command
You could do this by creating a close button with the worksheet- Do this via insertin ga prompt in Macro.
Dec 20, 2008 | Microsoft Computers & Internet
Macro code for copying a range of cells from one Excell w/sheet t
You did not respond to my claification request. Here is some code that might help, it copies a selection of cells going down until an emty cell is found and across until an emty cell is found. This is form an earlier version of office but should comeclose to woring in 2007.
Sub copyrange()
' copyrange Macro
' Macro written by Royal 11/22/2008.
'save the return values
wksname = ActiveSheet.Name
returncell = ActiveCell.Address
searchfor = ActiveCell.Value
'go to first worksheet and find entered value (note this is a value serach)
Worksheets(1).Activate
findfor = "A1"
On Error Resume Next
findfor = Cells.Find(What:=searchfor, After:=ActiveCell, LookIn:=xlValues, LookAt:= _
xlWhole, SearchOrder:=xlByColumns, SearchDirection:=xlNext, MatchCase:= _
False).Address
If findfor = "A1" Then
erwks = ActiveSheet.Name
Sheets(wksname).Activate
er = MsgBox("Search item not found on Worksheet" + erwks, , "Search Error")
Exit Sub
Else
findfor.Activate
End If
Cells.FindNext(After:=ActiveCell).Activate
'save this address and start searching for copy area boundaries
begcell = ActiveCell.Address
begcl = ActiveCell.Cells.Column
begri = ActiveCell.Cells.Row
'search amaximum of 1000 rows and 676 columns
endri = begri + 1000
endcl = 26 * 26
maxrow = 0
maxcol = 0
For col = Cells.Column To endcl
If Cells(begri, col) = "" Then
maxcol = col
col = endcl
ri = endri
Else
ri = begri
End If
For ri = ri To (Cells.Row + 1000)
If Cells(ri, col) = "" Then
If ri > maxrow Then
maxrow = ri
End If
ri = endri
End If
Next ri
Next col
maxrow = maxrow - 1
maxcol = maxcol - 1
'copy the selected area
endcell = Cells(maxrow, maxcol).Address
crnge = begcell & ":" & endcell
Range(crnge).Select
Selection.Copy
'go back and paste it in
Range(returncell).Select
' use this if yo want to paste formulas etc.
'ActiveSheet.Paste
' use this code if you want to paste values instead of formulas etc.
Selection.PasteSpecial Paste:=xlValues, Operation:=xlNone, SkipBlanks:= _
False, Transpose:=False
Nov 20, 2008 | Computers & Internet
Macro
Hi alwinkumar
You can set a default value in most form items under the properties of that item. Look for "value". You can also do this in code, by setting up a sub routine to set/reset the values on your form. Then just run the sub routine before you open or enter the form.
Private Sub resetForm()
'formname.itemname = value
UserForm1.Label1 = "Hello World"
End Sub
For the second one you have a couple of options, you can find the bottom on the data and store the row index in a variable, use a loop to find the next empty cell in a row, and store the value or you can use the current region method to select all the cells with data continously touching the selected range. Example below
numberOfRows = Sheet1.Range("A1").CurrentRegion.Rows.Count
Jul 16, 2008 | Microsoft Office Professional 2007 Full...
Continueous Printing
The best way is to write a small code in a macro. Basically you change the number in the datavalidation popup and print it automatically. If you want I can write you the code, but i will need the worksheet. Write me to lucho_lnc@yahoo.com
Jun 01, 2008 | Microsoft Excel for PC
Attendance sheet in Excel
Hi KDina,
If you need me to work on this project for you please contact me at hdbas8@gmail.com
May 17, 2008 | Excel (SS8SATAS5128400R)
Unsure of correct formula
You can add a reference from the worksheet 1 to all other worksheets
Is it OK?
Mar 08, 2008 | Microsoft Excel for PC
EXCEL
It is very useful to learn excel shortcut realy i thank you
Sep 26, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
