Question about Konica Minolta PagePro 1350W Laser Printer
Refill toner konic minolta 1350w
Is it possible for the average guy to reload thesew cartriges and chip, it looks as though the cartridge has a clear plug for refilling could it be that easy? thank you
  • altor_2001 Jul 14, 2008
    What kind of refill toner could be used for konica minolta 1350w?
  • 4 Answers
Guys, reffil this cartridge is so simple, just buy a correct toner dust bottle (google etc) and electronic information about toner level - chip. For average guy is good to know that you need to be carefull with manipulation with dust, if you will shake is like flying water.
Vertical streaks can make also OPC drum cartridge, the best solution is change drum unit.... Or remove drum from unit and clean drum with alcohol and soft cleaning cloth. Beware dont touch the green layer with fingers.
Posted on Oct 17, 2008
Hello
i just installed a new cartridge , but i still have vertical streaks on my sheets
do i need to get the toner clean , and what product do i use ?
thanks again for you time / help
Posted on Sep 19, 2008
Toner error
if replaced the cartridge ,The problem is something else.but u refilling the toner, maybe the chip set on the cartridge is gone.
Jan 05, 2014 | Konica Minolta Bizhub 363 Copier / Printer...
Toner error
There are chips on the toner cartridge, that how the printer known it got a new cartridge so refilling does not work.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 05, 2014 | Konica Minolta PagePro Office Equipment &...
My Minolta Magicolor 2500W printer indicates that it is out of black toner. I have never changed the toner cartridge before and cannot find the instruction manual. (bought it almost 3 years ago...) Do I...
Firstly buy a black toner refill and a "CHIP". The chip is a small printed circuit carrying a chip, mounted on the top right hand corner of the toner cartridge held in by a small cross point screw. Remove the cartridge and looking at the right end you will see a round (About 3/4 inch dia) plastic bung. Lift this bung out and carefully refill the cartridge (The refill supplier will probably clarify this I am saying). Replace the bung, clean up all the messy dust and remove the old chip replacing it with the new one. Make sure you dont lose the little screw and insert it fully without over turning it. Thereafter all should be OK.
Dec 05, 2009 | Konica Minolta magicolor 2500W Laser...
Konica minolta 9J04 refill
Unfortunately you have to replace the chip or to reset it after the toner refill. The chip keeps count of the number of pages that was printed with that toner, so there is no easy way out.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Nov 20, 2008 | Konica Minolta PagePro 1350W Laser Printer
Konica magicolor 2400W
To clear chip after refilling toner cartriage.
Go to "Tonerfillyourself.com" I bought refill toner and it includes a new chip and it's not hard to replace it. (Comes with instructions)
Apr 09, 2008 | Konica Minolta magicolor 2400 Laser...
Toner cartridge
As well as adding toner, there is a chip that must be replaced (with the cartridge bottom up, the chip is towards the right side and held in place with two small screws). The chip can be purchased separately but is included with refilling kits that are overall less expensive than buying the parts individually.
Dec 23, 2007 | Konica Minolta PagePro 1350W Laser Printer
Error light
You have installed a refilled cartridge without changing the chip on the bottom of the cartridge. Your error light will flash and also upon starting your computer, you will probably get an error screen saying the bi-directional connection is disabled. The printer should still work, but will be slow because it recycles between each page. My error light has been flashing for some time, but when I send a document to the printer, the error light stops flashing and the printer prints. After the print job is done, the error light resumes flashing. The only real solution is to replace the chip on the toner cartridge with a new one.
Dec 18, 2007 | Konica Minolta PagePro 1350W Laser Printer
PagePro 1350W
Time has nothing to do with how long a toner cartridge will last. What is the page count on the cartridge?
Don't expect too much from it if it is the original cartridge that came with the printer as they have a very short fill.
Dec 05, 2007 | Konica Minolta PagePro 1350W Laser Printer
"Can't Detect Genuine Toner Cartridge"
minolta printers work on "chips" if the chip atached to the cartridge is not original minolta you better change it.
Oct 28, 2007 | Konica Minolta PagePro 1350W Laser Printer
Error code
toner chip is gone replace cartrige
Oct 08, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta PagePro 1350W Laser Printer Logo
244 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
