Both issues sound like they are related to a non-connected or loosely connected remote wire on the
Basslink.
If you're using RCA preamp wires to connect your stereo to the Basslink, make sure the remote wire input on the Basslink is solidly connected to the stereo's remote output.
If you're using the speaker level inputs on the Basslink and not the RCA preamps, make sure the remote input is
not connected, as the Basslink will automatically turn on when it senses the speaker level inputs are active.
I already have thicker gauge than required and I've tried the sub in another car (different wiring, head-unit, etc.) with the same problem. The sub has been working fine for years.
I believe this is a known issue with Infinity and I was hoping someone had solved it by possibly repairing the subwoofer.
Thanks!
-Ryan
NO OUTPUT SERVO NOT LIT POWER IS ON FUSE GOOD PLEASE HELP
Hi, I have the same issue where I've connected my Basslink in my Lexus RX300 and the unit's LED is lit red, but no output from the subwoofer. I've tried hooking up the IPOD to the line input on the sub to see if there was an issue with the speaker lever input as a test, but still not working. Can someone please advise what can be the issue??
Thanks...
Jay
email: [email protected]
I have the same issue where the unit is connectd in my Lexus RX300 and the power LED is lit red, but no output from the subwoofer. I also tried connecting the unit to my ipod with a line input to see if there was an issue with the speaker level input, but still not working. Can someone please advise as to what the issue can be?? Thank you
Jay
Jay
I'm having the same issue w/ my Basslink in my 08 Mazda 3. The power is on but the servo light does not come on. I checked the fuse but it looked ok - it's a blade style fuse, is there a physical difference between a blown / unblown fuse? This was all proceeded by the phantom bass sounds and then the sub stopped outputting. This was Friday. It's Monday and it's still not working. The last time it happened, the sub came back on by itself and I just thought it had overheated or something.
I'm taking my car to BB to get an XM receiver installed, so I'll see if they can put some thicker gauge wire for the ground - the one that is connected is pretty thin. Hopefully that fixes it ?
So the Best Buy tech told my Servo died. Sent the sub to be replaced today.
