Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
Problem for Hitachi 51F500 51 in. Rear Projection HDTV-Ready...
Blue colour is ghosting off to the side
By minus40 on Mar 19, 2008
Magic focus has trouble on the blue and displays a 5 in the bottom right corner. When I try the manual option the blue is off the grid by quite a bit.The horizontal lines are pretty close but the vertical lines are in the middle of the grid. I cannot move the lines horizontal but can move them vertical. Also it seems to work somewhat near the edge of the screen and nothing in the middle.
No obvious hot or burned resistors etc than I can see with a quick look
Comments:
Mar 19, 2008
- Ok, it has two IC's. One is an STK-392-110 and the other is a -150. Should I replace these with the same or I have read about some upgrade. A STK-394-160? I've also read something about some repair kits that would come with some resistors that may need to be changed.
It's a DP-23 chassis according to a sticker near the rear inputs.
Same Problem
Mar 20, 2008
-   have the same problem but with green-   Guest
Best Solution
posted on Mar 19, 2008
Helpful)
Slinteriors
Rank: Guru  Hitachi Televisions & Videos  Expert
Rating: 89%, 3802 votes
blue convergence IC needs replacing. That should have 3 ICs one for each color if so you only need to replace the blue. but if it has only 2 ICs then you will need to change both. If you need further info let me know.
Was this helpful?
Yes
No
Solution #2
Not Rated)
crikett
Rating: 87%, 479 votes
You should use STK392-150 for both. Do not use the 394's. You must check all the supply resistors on the convergence panel. They will be anywhere from 1.2ohm to 2.8ohm and I mean ON THE MONEY. No room for error. I hope when your done you know how to re converge the set of which it will need. The average repair for this is around $250.00 in the home. Not a major repair but can be time consuming. Keep me posted!
Was this helpful?
Yes
No
Popular Solutions for Hitachi 51F500 51 in. Rear
Questions and Unsolved Problems for Hitachi 51F500 51 in. Rear
Do you recommend Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television?
Answer
Answer
51F500 MODEL NOW IS ONLY SHOWING THE GREEN TINT AND VERY LITTLE BRIGHTNESS. IT IS DARK IN THE BACK... (More)
Answer
how to hook laptop to my hitachi 51f500 tv fto watch movies. i am told i cant because the tv would... (More)
Answer
After turning on our TV, we just see a blue and gray striped screen. We had this problem before a... (More)
Answer
TV was doing the below on and off, not every time it was turned on. Then today the red power button... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
