Blown speakers 8ohm rated to 500 watt
RSQ NEO E500 DVD KARAOKE PLAYER CONNECTED TO AN EASY KARAOKE SA-5860 PROFESSIONAL KARAOKE AMPLIFIER HAS BLOWN BOTH SPEAKERS.
DID'NT
Posted on Mar 22, 2008
SOURCE:
I'm having a bit of a problem with my RSQ NK-2000U. The voice is lagging when singing. In other words, I say something like, "Testing" and I hear it about half a second to a second afterwards. ...
The Karoke is usually se with a reverb that could make it sound that way. Check the vocal settings in the machine for correcting that and time delay setting.
Dec 25, 2014 | RSQ Neo Nk-2000 Dvd Karaoke Player Nk...
Hi, after about an hour of playing, my machine starts missing parts of song, often sticks and skips tracks, it does this on all the formats that we use, ie CD+G , Neo+G, Zoom DVD, RSQ SH01 [ 1200 songs ]...
This sounds like a CD read error problem. I would clean the read head (read instructions for this as the head is very fragile).
If there is any chance of warranty being active, exercise it.
ALSO verify the discs are CLEAN with no smudges on the read surface. If you have dirt, clean with windex, rinse, and wipe OUTWARD radially, not in circles.
Remember these disks read from inside out unlike phonograph records.
Feb 15, 2011 | RSQ Neo Nk-2000 Dvd Karaoke Player Nk...
I have the RSQ NI-2000U Karaoke with Neo-G. I took
Yes, problem solved. Both RSQ (maker of Karaoke) and Zoom Karaoke helped solve this issue. RSQ told me CD G's should work, but most do not as it is the way the co. that produces them writes their discs, but could not tell me which ones are the good discs or not and Zoom Karaoke discontinue Neo G's (the other format that scoring is suppose to work on) because they were not selling. If you can find them they have kids songs or foreign language. I bought this from the Guitar Center and 4 times they could not help me. Did they really not know such a simple answer??? They 1st sold me a powered Karaoke for my powered speakers. I found out from an audio specialist that you can not run powered anything to powered speakers. Why did they sell it to me? I took it back and then this problem. I have spent $1000's with them. I wonder?? Anyway, this one goes back and I'm off to find a new one )-:. This is a great site and sometimes I need expert advice. An audio specialist should have been able to help, but there was no mention of Karaoke and I believe you have to be familiar with this product to solve this issue. I will however use this site again. Thankyou! Ernie
Jan 04, 2010 | RSQ Televison & Video
I have lost the color from my rsq neo 500 kareoke player and have tried your advice on here that didnt work please help me
on the remote control there is a np button just press it and it restores the colour back to the screen i spent 20 dollars for a cleaner for my optic laser which had no effect whatsoever and thought it was a problem with the optic laser as your engineer diagnosed it would have cost me a couple of hundred pounds to have replaced thank heavan for my call to the company i purchased it from they told me immediatly what to do and bingo it worked and the information i recieved from your two experts was totally wrong
Dec 07, 2009 | RSQ NEO-E500 DVD Player
My Yamaha P4500 burned my speakers rated 500 watts.The clip lite did not lit, so I pressumed it is operating normally
Chances are your speakers were "fake rated" as are most consumer quality speakers.
Unless the speakers were rated for CONTINUOUS power at 500 watts each you could easily destroy them with that amp.
Check the DC bias out of the amp. If it is under a volt, your speakers were fake rated.
This fake rating is to sell speakers and depends upon average music programing that does not have continuous high level.
Get professional speakers in MATCHED cabinets that have CONTINUOUS pwer ratings above what the amp can produce. ALSO suggest you put fuses in your speaker leads to protect the speakers.
WITHOUT proper cabinets, the speakers can be blown.
You should probably get a sound level meter to check that you are not damaging your ears. No fun in later life requiring expensive hearing aids! There are professional quality meters for about $140 on eBay.
Nov 02, 2009 | Yamaha P4500 Power Amplifier 2-Channel
Screen rolls and no color
your player or tv maybe set on pal secam try changing it to auto or ntsc
May 29, 2009 | RSQ NEO-E500 DVD Player
No sound from rsq e500n
S-VIDEO only carries the video signal and NOT the sounds.
You would also need to hook up the audio leads (red nd white phono) also for it to fully work.
Dec 06, 2008 | RSQ NEO-E500 DVD Player
Door wont open on the RSQ E500 player. seems to freeze when open button is pressed
I found the drive mechanism to be stuck. Also there was a little oxidation on the pins on the drive tray plug. Solution was to move the lever underneath and to the front of the drive to free the mechanism, and remove and clean the pins on the plug. Worked fine after that
Nov 08, 2008 | RSQ NEO-E500 DVD Player
RSQ e500n
did the same thing on setting up! there is either a p/n or v-mode button on the remote try pressing it a few times! hope this works for you
Dec 22, 2007 | RSQ NEO-E500 DVD Player
103 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
