Question about Daewoo DTQ-19P2FC 19" TV
Mysterious black box?
Ive had my daewoo TV for years now with no problems. Today I come home and turn it on...and there is a black box that is taking up half of the screen. When i go to change the channel the box disappears...and then comes back moments later on the new channel as well. I went throught the entire menu...I can't get it to go away....any ideas? Or is this tv just done?
  • 97 Answers
Sounds like something is imposing Picture in picture on your scrren with no source attached to the other picture. Could be cable or Sat or some other device, or TV PIP.
Posted on Mar 19, 2008
SOURCE:
Black box blocks out lower half of television screen
Check your closed-caption settings. If you have captions on and set to "text" mode, this can happen. The TV blanks out the area on the screen where the text should go, but there's nothing to display. Turn off captions or set for regular caption mode, and that should clear up the mysterious box.
Jun 02, 2011 | Jensen Q2749J 27" TV
Black vertical line on screen periodically- but most of the time
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Sep 20, 2010 | Daewoo DTQ-27U4SC 27" TV
Samsung ht-bd1220 ipod problems.
Having the same problem- did you manage to sort this out?
Apr 05, 2010 | Samsung 5.1 Channel Black Blu-ray Home...
Square box in middle of t.v. black everywhere else.
Turn off the closed-captioning. If it's set for text mode, the screen will blank out an area for the text to be displayed. On channels or programs where captions aren't being used you won't see any problems, but other times you'll have the mysterious black box. Many TV remotes have a single button to control captions, so it's easy to get into text mode without knowing it.
May 03, 2009 | Broksonic TV
There's a large black blank square in the center of the picture. how do i get rid of it? thank you
Check your closed-caption settings and make sure you have captioning turned off. You probably have it set for "text" mode now, and this causes the black box on some channels and programs. The TV is clearing the area where the text would be displayed, but there's no text. Most TV remotes have a single button to access caption settings, and it's easy to change the settings without knowing it. Then you're stuck with the mysterious black box.
Mar 27, 2009 | JVC LT-23X475 23 in. EDTV-Ready LCD...
Daewoo TV model DTQ-27U4SC turns on by itself
A physical button on the tv is probably stuck / failed. In the past ive salvaged tvs by opening them up and disconnecting the switch boards and used a remote.
exercise the buttons gently and take note of any that crunch or make funny feelings noises as they push. It might start working after a gentle workout.
Feb 13, 2018 | Daewoo DTQ-29S1FCN 27" TV
No channels can be detected have tried 2 Daewoo DS608P boxes connected to same telly but same thing happens. Signal strength seems fine boxes have been working fine for years.
I am the same. Not a sausage from my same model Daewoo freeview box today. Scans and re-scans and not a single channel to be detected.
Rob
Jul 05, 2008 | Televison & Video
Black box showing up while viewing DVDs
Go to your TV remote, in the menu find the closed caption or sometimes it is on the remote itself. Turn off the closed caption. this should solve your problem. Good Luck
Mar 28, 2007 | Sony DAV-C990 System
Daewoo DTQ-19P2FC 19" TV Logo
115 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
