Question about Gateway MX8711 Notebook
Gateway MX8711 USB 2.0 problem
I keep getting the "This device can perform faster..." on my USB 2.0 ports (Gateway MX8711). Any advice?
  • dwagner13 Mar 31, 2008
    That's not the problem...I have usb 2.0 ports and am plugging a usb 2.0 device, but I'm getting the error that it is not a 2.0 port.
Posted on Mar 30, 2008
  • 111 Answers
It`s normal when you plug a usb 2.0 device into a usb 1.0 port i get that all the time it`s ok
Recently, when I insert a USB flash drive into my laptop's USB port, I get the message: This USB device can perform faster if you connect it to a HI-SPEED USB 2.0 port.
Your laptop has USB1 port and the USB 2 message will appear if you plug an USB 2 device into this USB port.
You maybe able to upgrade the USB port to USB 2 if there is a BIOS upgrade available from the laptop manufacturer's WEB site.
If not you maybe able to get an USB 2 PCMCIA card to install into the PCMCAI slot on your laptop.
Dec 04, 2012 | Computers & Internet
USB Port can preform faster error message
This is because you are plugging in a USB 2 device to a standard USB port, or a USB 3 device into a USB 2 port. The computer is just telling you that if you upgrade the hardware, the device will work faster. Its more of an information message than an error. Your device should still function fine.
Jun 28, 2012 | Dell XPS M1530 Laptop
I keep getting message saying my pc will run faster with 2.0 hi-speed host. how do i get it
Hi! Welcome to FixYa!
USB versions are USB ver 1.1 and USB 2.0 and USB 2.0 has faster transfer rate.
When you're receiving this kind of message, that means you're using a USB device that is compatible with USB 2.0. This happens when you plugged in a USB 2.0 device to a USB 1.1 port on your computer. It simply notifies you that the USB device can perform faster when you have an available USB 2.0 port. I'm not really sure what kind of computer you have and what version of windows you have but you can actually check if you have USB 2.0 by going to Device Manager, click on Universal Serial Bus Controllers and look for "USB2 Enhanced Host Controller" if you don't have this, that means your computer has no USB 2.0 port. Hope this helps.
Jul 02, 2011 | Computers & Internet
Windows 7 64bit with support for USB 2: when I plug my pendrive in a USB port, there's an advice saying that if I plug it into a USB 2 port, it will perform faster. But how do I know which port is USB 1...
I hate this message.
You can use a program like PC Wizard from CPUID that will tell you what all of you pc specs are.
From your specs you may not have usb 2 ports.
Device manager should also say what usb ports you have.
The best ports to use are the ports on the rear of the computer, front usb ports sometimes dont have as much power to drive external hard drives or high drain devices
Jul 10, 2010 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
USB's slow and external drive
For the USB ports, you may want to verify that the drivers for the "enhanced USB" are up to date and for USB 2.0 or 1.1. USB 2.0 ports are generally backwards compatible for 1.1 devices. The "enhanced" does indicate USB 2.0 controller. 30mins to backup 3GB to your external drive is a VERY long time. USB 2.0 transfers data up to 480mbps, but if you get an error message indicating that the device can perform faster on a 2.0 port, you maybe transferring data at 12mbps which is USB 1.1 speed
To speed up the transferring of data, identify which USB contoller in Device Manager is the USB port you're having a problem with, and delete it from Device Manager. Then, plug in your external drive into a USB port its never used before.
As for the naming of hard drives, Hitachi partners with several drive manufacturers including Dell and IBM.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Feb 22, 2010 | Philips Computers & Internet
Hello, I'd like to know why my Dynex Wireless N usb adapter keeps disconnecting from my laptop, to reconnect I have to unplug / plug back to get signal, then I get signal for a short period of time then...
Try turning off Wireless Zero Configuration,in services. & disable on startup. Start>>Run>>services.msc navigate down till you find it, double click & change.
Feb 10, 2010 | Dynex Enhanced Wireless-G USB 2.0 Network...
The harddrive wont power up witout the power cable attached to an extra usb port but now I keep getting a message saying USB device not recognised and when i go to the device manager it says unknown usb...
You need the power from the 2 USB ports in order for the Drive to have enough Power.
Try moving the USB Ports to another Port or Flip Flop the 2 USB Cables.
Another option is to uninstall the unknown device. Remove the USB Cables, Uninstall Shut Down, Re-Start.
NOTE: Certain Ports on your System are USB 2.0 and some are not. Try to use the 2.0 port listed in the Manual... it will be faster and may carry the Power.
Jan 07, 2010 | LaCie 160GB Little Disk USB2/FW400 160 GB...
Dear sir, I am having Transcend 2 GB pendrive but when I insert it in my computer, it gives message THIS DEVICE CAN PERFORM FASTER IF U CONNNECT IT TO HIGH SPEED USB 2.0 PORT and its speed is also ver
If you have a USB port on the back of computer plug it in there. Or use USB extension if it is uneasy for you to plug your pen drive from time to time. From there you can hook up your pen drive much easy.
Apr 13, 2009 | Computers & Internet
USB2 high speed not recognize
Try opening up the device manager and unistall everything in the Universal Serial Bus Controllers. Then reboot and let windows reinstall the USB controllers. Windows should now be able to recognize properly USB2 devices.
Feb 22, 2008 | ASUS M2A-VM (0610839149438) Motherboard
Gateway MX8711 Notebook Logo
243 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
