Question about Onkyo TX-SR601 Receiver
Power We've been using this unit for about 2 years and it's worked perfectly until today. It just won't power up at all. Is there a fuse or something I can do?
  • 2,130 Answers
1. Make sure the AC outlet is good.
2. Make sure there is no damage to the AC line cord.
3. Look to see if there is a fuse at the rear of the unit. It's usually located inside a black circular housing with a screw off cap that says "fuse".
If not, unplug the unit and remove the outside cover. Look for a blown fuse on the motherboard or power supply. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto partsPower - 4.gif store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Mar 19, 2008
Dr Mercola Pure & Clear air purifier model# PC_AP2000. Unit stopped working, will not turn on. Cannot find a fuse in this unit. All else is in perfect working order. Thank you for your help.
The unit would be fused through the circuit breaker it gets power from in the main box of the house or in some cases a sub box to the main house circuit breaker box. If it is tripping the breaker something is seriously wrong and to reset over and over causes a fire risk, call a repair person.
Jan 24, 2017 | Heating & Cooling
What causes microwave to blow new fuse?
The only thing inside a microwave oven that draws enough current to blow a fuse is the magnetron that generates the microwaves to provide the cooking power. Based on the age of the unit (approx 15 years) it is most likely best to just replace it as repairs at that level are not cost effective. Newer units cook better and faster using less power these days.
Jul 02, 2015 | Sharp Microwave Ovens
Intermittent Power Loss
Take the unit apart and carefully inspect the wires under the keypad...short of that..junk it and get a new one. It seems they just don't make things the way tey used to.
Nov 19, 2013 | Samsung SMH9187 Microwave Oven
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Sharp R-1870F Microwave Won't turn on
Could be just a fuse but probably the diode pack or magnetron.
May 24, 2017 | Sharp R-1870 Convection/Microwave Oven
TV turns itself off??
Take a second look in the power supply where the power cord goes for bad caps----a few examples:
Good one on the left and puffed up one on the right
Extreme example of ones the arrows point to and notice all the perfectly flat tops on others
May 28, 2012 | Televison & Video
My Bernina Activa 220 won't turn on. This has happened before, and I've always tried plugging/unplugging, switching outlets, etc. In the past something has eventually "worked" and once...
Could be almost anything ! Do the usual simple checks - fuse in the mains plug (should be 3A), have you got another piece of equipment (radio etc.) that uses the same 2-pin plug for power - use it to check that the mains cable is OK. If the mains cable is OK, it maight be the switch on the power supply module or the power supply module itself ('L'-print), but could be more ... check if the sewing light or display backlight is coming on, but if completely dead, your only solution is to get it checked-out by a Bernina service agent.
Nov 05, 2011 | Bernina Activa 130
How long should i charge my jump box
I'm not familiar with this model, but other boxes I've used have all had some kind of power level indicator to show their charge level. I'm sure yours does too. Charge it at least until the indicator shows it's full. You can leave the unit charging for as long as you want, actually. The charging circuitry drops to a low trickle when the unit is fully charged, and won't damage anything by overcharging. (We have one where I work. As soon as we're done jumping something it goes back on charge, and it's over three years old now.)
Aug 11, 2011 | Xantrex Technology XPower Powerpack 200...
Kenmore Elite HE3 front load dryer no power
Yes. Remove the kickplate and check the continuity of the thermal fuse located on the blower housing.
Feb 23, 2009 | Kenmore Dryers
Kenwood KAC-9152D Car Amp
use a multimeter to check for power on the +ve wire, could be your fuse, it only rus a sec when you jumper the remote to +ve because the remote cannot give out the nessary current to run the amp.
Sep 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Onkyo TX-SR601 Receiver Logo
207 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
