Hello...my printer has a problem when the paper is fed into the machine, it goes in straight then gets caught before it gets to the printing heads causing the paper to get chewed up. There appears to be no paper stuck in the mechanism therefore I am stuck!!
Anybody any ideas?
I'm also having this problem!!! but my printer keeps printing even with the paper stuck even though its not printing on the paper.. i've tried anything? has anyone had anyproblems?
When your Epson printer's print head is clogged , then the red light for your ink and paper out is blinking. In this movement, the printer print head is blocked due to foreign objects or jammed paper.
Hello!
To solve your problem follow the instruction.
1.Paper must be straight, don let them curve.
2.Paper must not wet, should be tried.
That is the only way to solve problem.. good luck
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs. Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. Try cleaning the rollers with methylated spirits
If you are getting the message printer neeeds a service I suggest you get your ink pads cleaned straight away before your printer locks on you Two alternating flashing lights
You need a service utility for the R265 to reset it. you can find one of these on the net free of charge some people are selling them for a fiver but why buy what you can get free if you have problems or need
more info contact me at [email protected] or MSN using [email protected]
You need to look inside the slot where the paper is loaded with a flashlight and small mirror. Usually the only reason that happens is when something has fallen in where the paper goes. I usually find pins, paper clips, candy wrappers, or jewelry dropped inside. A paper clip straightened out can help remove the objects.
Most printers now are made of plastics and very light…when you store your printer in hot enclosed place that will affect the printer, and you can see the result on the prints, paper feeds, etc.you need to clean the printer if you did not used for over one week by conducting software head cleaning and open the door for the paper feeder and clean all around the inside…you have a jammed paper in the back that push the feeder out from the track and end up been shredded, make sure that all the doors closed very good and that the paper tray has the side track very close to the paper from the sides so the papers do not move side way when they go inside the feeder…Let me know if this what you are looking for, and please rate my service so I am able to continue serving everyone and improve on it.
Paper feeder problem. You must open case and paper feeder.Check for all screw. spring, rubber and lubrication. If you never done, find diagram at printersiam.com. is printer paper jam berfore? and clearing jam by pulling paper form back?
you have probably knocked sensor out of position at the paper feed in area. To check you will need to remove the paper tray completly from machine, then tilt machine up in front and look where paper is fed in there should be like a black flag in that area. it is the sensor that tells machine there is paper.
Look to make sure that there isn't a small bit of paper caught in the wheels that push the paper through. Over time, even a small bit in the corner can destroy your printer.
