Question about Abit IS7 Motherboard
Need help i just got a abit is7 i865pe mb motherboard. i am trying build a computer i got board and cd drives and a sata hard drive put into place turned on machine went through a ide scan and came up at bottom of screen computer unworkable and gives you 2 options hit f1 or delete to to enter hit both of them and does nothing...this is my first time trying to do anything like this not sure if put something in wrong if there is a problem with motherboard...please help.....
    Genius:
  • 1,027 Answers
If you have more than 1 device on the ribbon cable, make sure they are both on CS(cable select) or one is on master and one is on slave.
Next disconnect all the drives from the board and just hit the del key to enter the BIOS. Select advanced tab to make sure SATA is active, otherwise you will bypass any sata and go only to ide channels.
Once the sata is active, check boot sequence and select CD/DVD as 1st boot priority save and exit, on the reboot turn unit off and attach all cables to the board. Reboot.
Posted on Mar 19, 2008
I didnt have any problems but i went to turn on the computer and the computer beeps one time then beeps again there is no patter just long beeps one after another what is going on!!!?
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
good luck
Sep 02, 2010 | Abit IS7-V2 Motherboard
Hi! I have a pc with abit is7-e2 motherboard.. And when i start the pc a red led turns on the board... There is no picture on the screen. I already checked the video card but its working
Just how did you check the video card if you get no image on the screen?
Try another monitor with your computer. If you still get no image, then it's your video card or another component.
If your computer will not pass the POST (power on self test) then you will not get any video output.
Culprits can be the hard drive, the CD, the memory, the motherboard, or the CPU. I would disconnect everything but the CPU, memory, and video and try to start it to narrow the problem. But first, try another monitor.
I've even seen a bad power supply that seems to work keep the video from working.
Jan 16, 2010 | Abit IS7-E2 Motherboard
Im just about to buy a SATA II 500GB hard disk for this MB, i need to know if this would be compatible with the MB??! Thanks
SATA 2 (SATA 300) is not backwards compatible with a SATA (SATA 150) controller. In order to use a SATA 2 drive on a SATA (SATA 1?) controller, the hard drive must have a jumper position to restrict it to using SATA (SATA 150), and a jumper must be installed. Some drives have the jumper position available (e.g. some recent Samsung), some don't (e.g. some recent Maxtor).
This information can also probably be easily found on your hard drive manufacturer's web site.
If your drive does not have the jumper position available, you must return it and get a SATA 2 one that does, or a SATA drive.
Jan 11, 2010 | Abit KW7 Motherboard
Sata harddrive max size for abit is7 e2?
hard drive can be as much you want does not have a max size ,anyway not the motherboard you have to worry about if you put bigger hard drive you shold change the power source .
Nov 13, 2009 | Abit IS7-E2 Motherboard
No sound,please help!!
try to download the sound driver from here  http://74.125.153.132/search?q=cache:http://www.sis.com/products/sis661fx_benefits.htm  . if it fails again then try to install windows xp with sp2 not sp3 ok.
Jun 14, 2009 | Abit SG-80DC Motherboard
Won't recognize onboard sound on IS7 - chipset is Intel 865PE
yeah i would say just keep trying to find a driver for it thats the problem is that it isnt installed..you could look under device manager and see if it even recognizes it right click my computer go to properties then to hardware and device manager under sound cards or whatever maybe u can get a more specific model number of the sound card good luck
Oct 26, 2008 | Abit IS7 Motherboard
ABIT AV8 not reading SATA ASUS DVD Burner
you should contact your computer servicing centre.the problem might be of the drive.for getting more knowledge about the ASUZ mother board and SATA please make use of your users CD which is given with every ASUZ motherboard.easily understandable pictorial reprasentation of the whole mother board are given there.by that you can even find out the problem in *********** board if any. if you are convinced please rate me
Sep 22, 2008 | Abit AV8-3rd Eye Motherboard
Motherboard does not recognise new SATA hard drive
Is your board an ABIT? If so then here is the link to select your motherboard and download the latest BIOS. Make sure to read the web sites instructions on how to update your BIOS. Let me know if you still have issues.
http://www2.abit.com.tw/page/en/download/download_bios.php?pMAIN_TYPE=Motherboard&pSUB_TYPE=Socket%20754
Dec 30, 2007 | Abit KV8 Pro Motherboard
I can not install a Sata Hard drive 320 GB to a Abit MB IL9 pro
Hi this is the address for the Abit website. you will be able to get the information and a manual downloaded from there. http://www.abit.com.tw/page/au/index.php Regards mistyman
Sep 30, 2007 | Abit IL9 Pro Motherboard
Loading xp home edition
I can try and suggest you check the cables from you CD-ROM, any sort of damage the CD might have. Or then again, if your Hard Drive is SATA connected, then you'll need to load the SATA controler (F6 on the windows instalation) And, in last case, either upgrade your bios or try a different CD-ROM drive unit. But I would defenatly put my money on the cables.
Sep 23, 2007 | Abit KV7-V Motherboard
Abit IS7 Motherboard Logo
76 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
