Gearhead install crazy talk asks for sn .when put in pc sn always says illeagle sn
1st You download Webcam Driver.
Crazy talk program from Gearhead wont take sn's
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
SOURCE: my gearhead webcam is not being reconized by my pc
Normal
0
Probably
has corrupt driver.
Try
disconnecting the Camera from the USB port and reinstall the CD or
Downloaded software program. When the program asks you to connect
the camera to the USB port, do so and it should work.
Then
to use it on the Web do this.
Web Camera’s have to be
setup on the program they are to be used with. Just installing the camera
on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
) set it up as follows:
The camera and audio should function properly. Your
friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
(http://www.soft32.com/download_30.html
C. Windows Live Messenger:
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so
you can chat and see family or friends you are connected to.
Hope this helps. Bud
SOURCE: GearHead Webcam doesn't alway work
Did you install the software or driver nessisary to run it
P.S you need the software for it to work
SOURCE: Gearhead Webcam lost the disc and need to install!!!!!!!!
i also have that problem before, my webcam's driver was broken so i cannot able use it for almost a week... but now i have downloaded the file for the driver and install it and after a minute, it's working!!!
i will share it with you guys..
i hope, it will work for you and solve your problem!
just follow these link:
http://www.pcgearhead.com/downloads_items.php?catgy=Web%20Cams
-Gj
SOURCE: i need a cd to
Hi bscara,
Here is the driver for your webcam:
WC535l Driver
I hope it works
Myke
