Question about Panasonic PT-44LCX65 Television
Green Spot I have a Panasonic PT-44LCX65 HDTV. It has developed a "GREEN SPOT" in the lower left area of the display. It is mostly visible when there are lighter colors in the general area. It is completely invisible when there arevery dark colors in the general area.
  • Royalg May 27, 2008
    I have a PT 44LCX65 and there is a green shaped square near the top left corner and it tends to be completely visible on completely white or bright colors but is completely invisibe when dark or darker colors are in that area... what causes this and what could this be a bulb problem if in fact im still viewing a beautiful picture w/ the exception of this green demon area???
    Sergeant:
  • 300 Answers
I believe the issue can be resolved by contacting Panasonic. Word is, the optic board needs an EEPROM upgrade. It's a quick fix (by a Panasonic technician) and it even be for no charge (confirm it with Panasonic!).
Posted on Mar 24, 2008
    Genius:
  • 1,913 Answers
Set your tv to original default factory settings.
then apply also good resolution.
your problem is most of solved
  • kishor khatri
    kishor khatri Mar 24, 2008
    hi
    also degauss the screen
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm...
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
I have a PT44LX65, Green and blue spot after lamp changed
It is better to contact your local Panasonic authorized service center. This issue is easy fix by connecting special Panasonic-issued tool (programmer) to restore corrupted file in EEPROM inside of your TV. Rear cover have to be removed, tool plugged in service socket and 15 minutes later your screen will be as good as new.
Without this tool - I would say it's impossible unless you have experience in hacking memory devices. And still got to find original file and download it into EEPROM.
Russ.
Apr 06, 2010 | Panasonic PT-44LCX65 Television
Light green and pink spots on my hd tv!!!
For the spots....
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was 4 years old and out of warranty. They came out last week.
So long as it is not happening by something you have done. It will be fixed free of charge. Call them, it solves the problem.
May 27, 2009 | Panasonic PT-44LCX65 Television
I have a green spot on my 2 year old 44" panasonic lcd tv.
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was almost 4 years old and out of warranty.
Apr 03, 2009 | Panasonic PT-44LCX65 Television
Green spot in same place of the screen
Its probably a defective LCD panel in the light engine. Contact Panasonic for assistance.
michtech
Feb 12, 2009 | Panasonic PT-44LCX65 Television
Spots on picture
I had the same problem. Panasonic is kind of a pain about the whole thing. You have to find out who your local Panasonic repair place is, tell them there is a service bulletin and they will get on it. You must be diligent! Do not take no for an answer! If it comes down to it, and the repair shop won't do it for you, then call Panasonic and endure a loooooong wait time. Trust me though...this is the issue. Once the eeprom gets fixed/updated/whatever, the picture looks amazing! Good luck.
Aug 16, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Red, green and pink on the TV
Possibly a magnet was is the reason.Can you Degauss from the menu>>?
Jun 03, 2008 | Panasonic PT-44LCX65 Television
Panasonic PT-44LCX65 Television Logo
255 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
