Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Remote has stopped working
We just moved in a new house and we reprogrammed the keypad outside the garage. the remotes have stopped working eversince we reprogrammed the key pad. Please help.
    Problem Solver:
  • 8 Answers
Its possible you held the learn button down too long, this will erase all remotes. The best way to fix this is to press the learn button once and the hold down the button on the remote until the lights blink, you will have to do this with all remotes.
hope this helps.
Posted on Feb 27, 2009
My opener seems to forget its program and needs frequent reprogramming
you are getting a break in power somewhere, perhaps a bad circuit board in the motor itself. the least expensive is to try a new remote.
Oct 28, 2014 | Sears Craftsman LiftMaster Chamberlain...
Remote capability out on garage opener
If you are having a problem with all your units that transmit a radio signal it is your receiver that is going bad. It is part of the logic board.
Jan 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
We can only get one remote to work when we reprogram the next one the first one stops working. the key pad is doing the same thing
You are probably not reprogramming the remote or keypad, but are using the remote to reprogram the receiver. But I can't get the instructions from the Chamberlain site without a model number. Here is their site:
http://help.chamberlain.com/help/en-us/programmingInstructions/
Jan 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Neither remote control will open door but wall mounted button wil
Make sure the code set inside the remote is the same as in the main reciving unit code.
Dec 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
HOPE THIS HELPS
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Security Garage Door
your car remote should work even from inside the garage... if not, just take it off the visor and go outside the front door and point it at your garage to open it. This is only a quick fix. You probably need to replace the batteries in your keypad or reprogram it.
Jul 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
196 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Marvin
Marvin
richie46
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
