2003 Ford Focus Logo
Posted on Apr 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2003 Ford FocusZx3 2.3L hatchback and it is making a grinding noise coming from the passager side and the grinding noise only happens when I am acclerating or going up a hill or at low speeds below 55mph it does not make that noise when it is at an idle. Please help
happycouple7
Level 2:
New Friend:
  • Expert 189 Answers
  • Posted on Apr 14, 2010
happycouple7
Expert
Level 2:
New Friend:
Answers
189
Questions
0
Helped
56572
Points
403
2answers
Abs light on/grinding and clunking in turns on front left side of 2003 ford explorer
Sounds like left front loose wheel bearing knocking ABS sensor out of range causing ABS light to come on and causing grind noise at same location. Grinding noise is probably rotor rubbing on calipar.
1helpful
4answers
What is the reason for front grinding when turning
This due to either a worn wheel bearing or a worn front drive arm.
The most common cause of a grinding noise when turning is a worn front wheel bearing. What happens is that the weight of the car is shifted on to that wheel as you make the turn causing the worn bearing to make a grinding noise.
2helpful
My 2002 ford expadition is still making the grinding whoop whoop noise, I took it to a machanic and they said it was the roter or brakes or ball joints, so I got all replaced on both sides and it is still...
If the noise only happens when you are moving, and it changes with the speed of the truck, its something that is connected to the wheels.
Road speed does not affect suspension noises like ball joints and spindles.
So it would be something like the brakes, axle joints or bearings, or something in the differential where the axles come together.
If the truck is 4wd you have front hub bearings behind the brake rotors, and regular bearings if it is 2wd.
2007 ford focus noise from airfilter box when turning steering from side to side?
did you ever get to the end of this problem as I have the same problem. When i turn the engine on and turn the wheel from side to side there is a really strange 'runmbling' noise coming from the air filter?Q
4helpful
2answers
Focus GRINDING NOISE during excellaration
I had the same exact problem with my 2003 Focus with 108,000 on it. Making right turns and accelerating was even worse. Had many ideas from differant mechanics saying it was wheel bearing, steering rack, loose heat shields, transmission...ect. Well after having wheel bearing replaced and steering rack replaced, the grinding was still there. It was finally discovered that the noise was coming from a bad motor mount on the right side. Had the dealer replace the motor motor mount and finally!!! the problem was solved. Thank God.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
