Question about Lands Phones
Ericofon ringer Hey Gents, wassup!?! here's what I've got. An old original Ericofon rotary dial, which works fine except for the ringer. Have been told that some of these had no ringer, but the ex-roomate I got this from told me that the ringer had been disconnected. I have a fair amount of electro-mechanical expertise, am familiar with and have the tools to attach RJ11 connectors, so when my natural curiosity got hold and I pulled the guts out, here's what I found. First, I'm not sure this is the original cord for this phone. Anyway, inside were four screws where one might assume the cord would attach. One has a blue wire, the other yellow. The other two screws are part of the big red (answer) button switch on the bottom of the phone. However, there were only three wires from the cord connected...one to blue, one to one of the button switch screws, the third going to an orange wire with screw connection at the bottom of the circuit board. So, is there any way to visually determine if this thing does have any kind of ringer/buzzer, and if so what are the proper connections? Reference RJ11 connector with tab down, pointing away from me. Have at it!!
Everything you need to know is right here: http://ericofon.com/work/wire.htm
Posted on Jan 08, 2009
How does the spring for the emergency release on the ringers work
Search Results
    [PDF]Bell Ringer Activities - Kentucky Department of Education
    education.ky.gov/cte/pa/documents/bellringeractivities.pdf
    Each day place a bell ringer activity on the board. A bell ringer is a short activity that ... Ask students: "What do you plan to do after graduation-college or work?
    Rotary dial - Wikipedia, the free encyclopedia
    https://en.wikipedia.org/wiki/Rotary_dial
    WikipediaWhen released at the finger stop, the wheel returns to its home position by ... While used in independent telephone systems, it did not enter service in the .... A relic of these differences is found in emergency telephone numbers used in ... In the late 19th century, the dial was refined to operate automatically by a recoil spring.
    CodeRED FAQs ' City of Blue Springs, MO - Official Website
Dec 26, 2015 | Cars & Trucks
Why won't replica rotary dial phone works well but won't ring on incoming calls
Whats a rotary phone? J/k we're not that old yet.
Because phone systems are no longer analong. The way a rotary rings is by an increase in line voltage.
Aug 08, 2014 | Toscano Design Pay Phone Pop Rotary Dial...
Rotary phone works won't ring
Check underneath. There may be a little lever there that controls whether the ringer works or not.
Aug 08, 2014 | LG Optimus M Rubberized Vintage Rotary...
Dse q-1559 Digital Multimeter
hi ,my q1559 is doing exactly the same ,are you using a rechargeable battery that is pretty old ? My point is I put a new battery in and it disappeared . I don't know if this is your problem but try cleaning the test meter probes connector, because the audible warning is telling you have a test lead connected to amps post whilst the switch is not turned onto measure amps..I used a cottonbud it fits perfect soaked in contact cleaner.
Feb 25, 2014 | Origin Video Game Consoles & Games
Home phone does not ring I know that it's working
Look for an internal setting that disables the ringer. This can be a ***** because most of us don't bother to customize phones like this and we never keep the manuals.
Check the manufacturer's web site for instructions or a manual.
There could be an external control to turn it down or off. The old 500 phone (black, rotary dial) had a metal dial you could spin to turn down the ringer.
You can always check a residential line by connecting to the demarc where the telco wires end and yours begin. Connect there and call in with your cell phone.If you get through, there but not using house wiring the fault is in wiring you own and you must pay to fix it. Don;t forget to reconnect the house when you are done.
Sep 23, 2012 | Lands Phones
Continuous dial tone on phone line . When i try to dial out- i just get a continuos dial tone- happening on my 2 cordless, landline is fine. Dont use a magic jack, changed out hardware, new cordless dont...
There are two possible answers to this problem. The first thing is to check on the cordless phones, is a 2 way switch, one setting is for DP=Dial pulse (setting for old rotary phones) 2nd setting is TT= Touch Tone. I would guess that the setting should be set to TT on both cordless phones for touchtone.
Second thing to do is to plug in the base unit of your cordless phone to a jack that currently has a landline phone plugged into it that works and test again. If cordless phone works OK then go back to the original jack that didn't work and reverse the wires in the jack: that is what is known as a "polarity" issue.
Aug 31, 2009 | Panasonic Lands Phones
My phone is stuck on rotary dialing. My handset had all the options but the dial mode. After caller id setup it went straight to languages and then started back over with ringer volume.
1) When the phone is in the standby mode, press menu/mute.
2) Press - to move the pointer to “Dial Mode”.
3) Press select/ch and the display will show the current setting.
(The initial setting is Tone.)
4) Press + or - to change the selection.
5) Press select/ch and a confirmation tone will sound.
6) Press end to exit.
Customer Help line for UNIDEN 1-800-297-1023
May 30, 2009 | Uniden TRU 448-2 Cordless Phone
Lands Phones Logo
269 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
