Question about LG Chocolate Clamshell VX8600 Cellular Phone
LG VX 8600 - My phone was dropped and now when powering on - it won't go passed the "Verizon Wireless" startup screen. I'm eligible for an upgrade through verizon, but is there anyway I can get my contacts off? Please help. Losing your numbers is brutal. Thanks. Eric [email protected]
Try plugging your phone in to a power supply so that it's running off a different power source, then power up your phone. You should then be able to copy off your contacts. This worked for mine which I'd left outside in the front lawn through the WHOLE WINTER and just found it after the snow melted. Sure enough it works, however I need to have it plugged in to a charger to actually use it. Give it a try, worked for me.
Posted on Mar 29, 2008
SOURCE:
How can I get my Verizon lg to turn on
Verizon Wireless Phone Guides - LG
www.verizonwireless.com/.../HowToControllerServlet?...
Verizon WirelessVerizon Wireless Phones. ... Note: Your model name appears on the screen immediately after turning on your device. *To view the PDF file, you may need to
LG G2 Support ' Verizon Wireless
www.verizonwireless.com/support/g2/
Verizon WirelessManage your device in My Verizon ...... Enable/Disable Voice & Video - Advanced Calling 1.0 - LG G2 ... LG G2 Simulator: Turning Airplane Mode On and Off.
Enable/Disable Data - LG G2 ' Verizon Wireless
Dec 10, 2015 | LG Cell Phones
My phone is lucky by the sos code
really yes! this phone is a lucky one, because
this is a refurbished LG enV VX-9900 phone ready for activation on the Verizon Wireless network ,their will be no need of sos code for activation
thank you
Dec 26, 2010 | Verizon Communications LG enV Cell Phone -...
No picture on Verizon LG VX 8000 cell phone
the screen may be cracked... if so you need to have it replaced
Nov 04, 2009 | Cell Phones
Env touch problems
Sounds like the software in the phone is corrupt. Take to a Verizon Wireless repair center and see if you can have it reflashed. Call ahead of time or visit verizonwireless.com to ensure that they can repair the phone.
You might also see if you're eligible for a new phone with a two year contract. That phone is an older model and it might be time for your upgrade.
Aug 24, 2009 | Verizon Communications LG enV Cell Phone -...
LG 8700 "downloading" error on startup
You may need to reprogram your phone. On Verizon you dial 228 then listen to prompts. They will finish and tell you it is complete. This should help you out. Good Luck.
Jul 06, 2009 | LG VX-8700 Cellular Phone
LG VX-9700 and bluetooth headset cuts out and choppy
Solution is questionable. Talked to Verizon Tech (Good support) and shortly to Plantronics. Both claimed to know nothing of a problem with the LG Dare and Bluetooth. Went back to the Verizon shop in the Mall to get it checked. We duplicated the problem on both phones and also used their phones (not the VX-9700). So, they are sending two new LGs to us via FedEx. When we came back to pick up the phones, the Tech did some research and did find info (Verizon) and Bluetooth. He did not elaborate.
Also there IS a Firmware Update for the VX-9700 and you must take it in to a Verizon that has a flash machine to upgrade the probably 03 to the latest, 05.
Thanks Also, hope this helps someone else experiencing Bluetooth problems.
Lou
Oct 03, 2008 | Cell Phones
Verizon warranty
if you are the main line on your account, then you may be eligible for an annual upgrade, so you can upgrade to a new phone, and not replace your choclate
Aug 13, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG Chocolate vx8550
I took the phone to Verizon and they tried a different battery. It worked fine so I had to buy a new battery
Jun 27, 2008 | LG CHOCOLATE VX8500 Cellular Phone
New cell phone
call or stop by Verizon. You will be eligible for equipment upgrades several months prior to your contract renewal date. You will have to renew your contract (usually 2 years) at the time you get new equipment. I have actually had better success going to a local "Verizon Authorized Retailer" than an actual Verizon store.
Dec 05, 2007 | LG VX6000
LG Chocolate Clamshell VX8600 Cellular Phone Logo
109 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
