Question about Xerox Phaser 7300DN Laser Printer
Jams when duplexing
Every time I try to duplex with the Phaser, I get a jam under the Fuser. We've replaced the fuser, but the problem persists. Any ideas.  We had been duplexing with no problem.
  • Ray Christensen
    Ray Christensen Nov 19, 2015
    duplex roller may be too slippery. Lightly sand it with sandpaper to roughen
    President:
  • 2,072 Answers
There is a set of clutches in on the upper back side of the right side door.
The inverter clutch tends to go bad on that cluster.
But if you are replacing one may as well do both. They are electromechinical clutches.
Posted on Mar 19, 2008
T632 duplex jams
Please ensure the power connector wires for the fuser are routed properly so as not to rub on the aluminum bar that is used during the duplex function.
Apr 03, 2013 | Lexmark T632 Laser Printer
I have an hp 4300 with a 13.12.00 error when the duplexer is installed
Here is a copy of the 13.12 error troubleshooting steps from the service manual.
1. Press the HELP ( ) button for
detailed information about
clearing the jam.
2. Press the UP ARROW( )
button and the
DOWN ARROW ( ) button to
step through the instructions.
3. Check the paper width and
fuser delivery sensors
(PS106, PS108) and verify
that the sensor arms move
freely. (See "Location of
printer switches and sensors"
on page 336.)
4. Check the inside of the
duplexer for scraps of media
that might have torn off when
a jam was cleared.
5. Replace the media-size
sensor (PS106) and fuser.
See "Location of printer
switches and sensors" on
page 336 and "Fuser" on
page 162.
6. Turn the power off. Remove
the duplexer and turn the
power on. If the error
message persists, replace
the DC controller PCA. See
"DC controller PCA" on
page 181.
7. Replace the fuser (PS108).
See "Fuser" on page 162.
8. If the error message appears
frequently, see "Paper-path
troubleshooting" on
page 295.
Feb 07, 2013 | HP LaserJet 2420 Printer
My HP 3035 often get jam inside duplexer if copy or print in duplex mode. I have change the formater, ECU, Fuser, but have not get result. Will anyone give me advice please?
We went through this with a client and ate up 20 hours of diagnostics time. It started when we installed a new fuser under the HP service advisory regarding worn fuser bushings. We tried another new fuser and had the same issue. Eventually we rebuilt the old fuser with parts from the new one and it worked, it seems that the heating elements on some fusers had issues. HP tech support, including engineering support (level 2 and 3 escalations) was not able to solve this problem.
Apr 23, 2011 | HP Office Equipment & Supplies
Hi, Hope you can help, A CP 6015 jams on dupex 2nd side on entrance to fuser,it looks like something to do with pressure roller release mechanisum as when released an actuator moves across fuser entrance,...
The document I was thinking of referred to fuser wrap jams. I did some quick checking of duplex jams though and this might give you some guidance to check for.
These errors refer to jams when repicking to print side 2.
Cause Solution The spring of the duplexing media-repickup-sensor lever is unhooked Check the spring and place it in the correct position. The duplexing media-repickup-sensor lever is damaged Replace the duplexing feed unit. Poor contact of the duplexing media-repickup-sensor connector Reconnect the connectors of the duplexing media-repickup sensor (J1945), intermediate (J1909, J1950) and the DC controller PCA (J4105). The duplexing media-repickup sensor is defective Check the duplexing media-repickup sensor by the sensor monitor mode. If the sensor is defective, replace the duplexing feed unit. Poor contact of the duplexing repickup-motor connector Reconnect the connectors of the duplexing repickup motor (J1771), intermediate (J1908, J1939, J1941) and the duplexing driver PCA (J4104). The duplexing repickup motor is defective Replace the duplexing feed unit.
Mar 10, 2011 | Office Equipment & Supplies
13.10.00 error
13.10.00 jam inside lower left door or 13.10.00 jam inside duplexer Description A media jam has occurred in the duplexer area of the printer. Action
  1. Check for stuck media in the paper path around the fuser and duplexer area. (See the paper jam locations in the printer section for further assistance).
  2. Make sure hat the lower left door closes properly.
  3. If this message persists, contact an HP-authorized service or support provider. Click here to go to "Handling persistent messages?? above.
Dec 19, 2010 | HP LaserJet 5200 Printer
When print 13.10.00 error appear
Welcome to fixya,
Hope this helps.
Dec 19, 2010 | HP Hewlett Packard LaserJet 5200 Printer
Duplex jamming of copy paper
Clean the rollers and clean the clutches mounted in the duplex cover to the rear of the duplexer Also the fuser mite be bad the fuser inter connects with the duplexer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 01, 2010 | Minolta DiALTA Di183 Copier
My printer says there is a jam in the output bin but there is no visable jam. HP color laserjet 2600n
Just try the steps
Jam in output bin - fuser area Error messageJam in output binalternates withOpen door and clear jam DescriptionA paper jam has occurred in the output bin near the fuser area. Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.
Jam in output bin - duplex area Error messageJam in output binalternates withOpen door and clear jam DescriptionPaper jam in duplex reversing area Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
Jan 28, 2010 | HP Color LaserJet 2600n Printer
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
Phaser 7300N paper jam
Problem:
    The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
Jan 23, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
308 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
