Question about HP Combo Case HP PAVILION Speakers, Mouse, HP Keyboard, Floppy (B09110)
Audio Problems the sound isnt working and the speakers are plugged in but when we go to put on sound it says audio is broken i tunes wont read my ipod isnt being reconized and keeps saying audio not working i dont know how to fix it
  • 106 Answers
See if the drivers are loaded correctlly, uninstall the audio device and scan for hardware change, see if installs properlly next time
Posted on Apr 06, 2008
How do I fix chill pill speaker. one of the speakers isnt working
check the speaker cable to make sure there isn't anything wrong with it. the cable could be broken.
Aug 04, 2013 | Apple Chill Pill Audio Speakers For Ipod...
I have no sound on my ipod and apopup say generic volume running
Damaged hardware is responsible for the most obvious iPod sound problems.
In such cases, Apple may be able to help you fix the problem, depending on the status of your warranty.
All iPods have a one-year warranty according to Apple's website.
Software problems can also affect your audio.
For example, downloading a non-certified Apple application can stop your sound from working correctly.
Returning your iPod to its original factory settings fixes many of these software glitches.
Plug in a different set of headphones and test the sound.
If that set works, your old headphones were the cause of your audio problems.
If your iPod still doesn't work, proceed.
Remove an application on your iPod Touch if you installed it right before your sound stopped working.
Hold your finger over the top left corner of the application.
It will shake.
Touch the "X." Touch the "Home" button.
Restore your iPod to fix other potential software problems.
Open iTunes. Plug the iPod into your computer with a USB cord.
Click on your iPod on the left-hand menu.
The iPod will be listed under the name you assigned it when you first set it up.
Click the "Restore" button on the menu.
Leave the iPod alone while it restores.
It may take several minutes.
Test the sound once the restore is complete.
The iPod syncs after restoration.
Once the sync is complete, the process is over.
Contact the Apple Technical Support line at 1-800-275-2273 if your audio still doesn't work.
Have your iPod with you.
Aug 01, 2013 | Apple iPod Audio Players & Recorders
There is a static noise coming from my ipods speakers and earphones
Thank you for your question.
It sounds like the jack on your iPod is a bit dirty inside causing static. Here are some things to try, assuming that your tracks are all stereo and none of them are mono tracks.
Try this:
  1. Power the unit off and the speakers off it they have a power switch.
  2. Get some rubbing alcohol and a paper towel.
  3. Pour a cap full of alcohol on the paper towel and grab the plug on your speakers.
  4. Twist the towel around tightly to clean the plug.
  5. Repeat this process on the earphone plug.
  6. Now take the speaker plug and push it in and out of the speaker jack about 20 times.
  7. Whatever you do, DO NOT pour any alcohol into the jack socket on the iPod itself.
If the problem continues, test your earphones and speakers with another product.
If they work fine, the jack in your iPod needs to be rewired.
If they don't work, then you may want to take your iPod, the speakers and earphones to your local Radio Shack store and show the Sales Associate what the problem is.
You may need to buy a stereo-to-mono audio adapter -OR- new headphones and new speakers.
If you still have problems after all of this, it may be time for a new iPod.
Feb 21, 2011 | Audio Players & Recorders
Dell a215 computer speakers can't get sound but the green power light is on
Well i sometimes go through alot of troubleshooting just to find its the most simple thing in the end.
Start at the source. Check if the green audio cable is plugged into the correct audio jack on the pc. Colours match up. (green with green)
And if that doest work check that the Pc isnt on mute.
To check this, there is a icon of a speaker on the task bar on the bottom right of the screen.
And if all this has been done and u still have no sound, plugg the speakers into a ipod or a similar device to see that the speakers actually do work. turn the volume up and down as well.
Hope this helps :)
Dec 19, 2009 | Dell A215 Computer Speakers
They wont give out sound there plugged into the front of the computer and in the outlet plug in BUT IT WONT WORK :( help
Be sure to plug into the "green" socket on the front of the computer, not the "pink" (microphone) or "blue" (headphone output from iPod) socket.
Try the speakers in the "green" socket on the back of the computer, to ensure that the speakers work, and the volume control is "high", and that you have not "muted" your speakers.
Some motherboards have a small "jumper" to enable/disable the front audio-output sockets.
Try the speakers when connected to the headphone-output from your iPod, to confirm that they work -- they could be quite quiet.
Nov 25, 2009 | Koss HDM 11 Computer Speakers
Speakers
Plug the speakers into your iPod. Any sound?
You may need to maximize the volume-control on the iPod *AND* on your speakers, but you should hear some sound, if the speakers are working.
Try a different set of speakers on your computer.
Make sure that you have not "muted" nor "minimized" the sound on your computer.
Make sure that the speakers are plugged-in to the "green" socket on your computer.
Sep 14, 2009 | Audio Players & Recorders
Red light isn't indicating it detects source
I have the same model as you.
Plug in the transmitting unit into a good working power outlet. Make sure you have the audio connected to a loud source. Turn on the source device producing the loud audio to be transmitted to your headphones. (This being your IPod - Turn it full blast). Now see if the transmitting unit's LED light is on. Check headphones for audio. (May have to tune in the headphones till green and adjust its volume as well).
Note: Some radio stations bleed over into the headphones and you may have gotten the "Beautiful Music" from this radio station frequency harmonic anomaly. Keep tuning your headphones till you hear your music or audio source.
I recommend that the source of your audio have its built-in speakers off, while still providing audio out to your transmitting unit, via an external audio output. Check your source manual or look for audio jacks on the front or back. There may be a setting to turn this on and for the main built-in speakers to be turned off as well.
If this does not work, unplug the transmitting unit, and then plug it back in again, after waiting for about 10 seconds - all while audio is being provided to the unit. It should come on.
Jul 26, 2009 | RCA WHP140 Consumer Headphones
Audio problems
To use the integrated speakers on this monitor you will need the audio cable. Most monitors with built in speakers has a single cable with a green jack on both ends. It would plug into the audio jack on the back of your monitor and connect the monitor to your soundcard jack on the back of your pc. Cable should be able to be purchased at any electronics/computer store. Hope this helps.
Jul 08, 2009 | AOpen F75PS 17" Flat Panel LCD Monitor
No sound
You need to have an input audio source on your receiver such as a DVD player or ipod. The radio is an internal source that is why yo uare hearing sound from it. One thing you could do is run a cable from the audio out jacks on your television to an input on the receiver, and then when you are watching TV select the input you put the cables in to hear the television sound through your receiver speakers.
Dec 23, 2008 | Harman Kardon AVR 225 Receiver
Computers & Internet Logo
85 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
