Question about Panasonic KX-T7730 Corded Phone
Panasonic Phone KX-T 7731
How do you change the time and date on the phones?
  • nephron May 11, 2010
    When I follow your instructions I get the message
    PITS- PGM NO?
    I tried entering 0 after this or 000 but all I get is 3 short tones and then nothing happens
    Any other suggestions?
I hit Program button, then the number 0, it will read out something like
080320 4 03:43 1
Where
08 - the year
03 - the month
20 - the day
4 - the day of the week starting from Monday so 4 is for Thursday
03:43 -Time
1 - PM 0 for AM
Type in what you want for date and time
Once done
I hit the "Auto Dial/Store"
Click on Program button again to exit
Good Luck!
Posted on Mar 21, 2008
6ya staff
SOURCE:
Does a panasonic kx t 7731 have built in voicemail and if so how do i program it
You need to get a voicemail system. The 7731 is just a phone, but it can be used to access Panasonic VM or Built In Voicemail in a TA-824 system. The external product is a model TVA-50 and it comes with documentation on how to interface it to your phone system. If you have an old KXT-308 or 616, or any other older Panasonic system prior to a TD-816/1232, you're going to have a problem.
Carl
Carl
Dec 06, 2012 | Panasonic KX-T7731 Corded Phone
Does the Panasonic KXT 7731 2-line have a music/message on hold port on it's KSU?
All Panasonic systems that the 7731 would plug into has an MOH port. You provide 8 or 600 ohm sound levels and do some programming to make it work.
Carl
Jul 20, 2011 | Panasonic KX-T7731 Corded Phone
Panasonic KX-t771, the light won't go out on the message and there are no messages
On my typical 7731, if I press the MESSAGE button on an idle phone, it tells me where the message came from. It could be from any internal station, not only the voice mail system.
Dialing 700# on the intercom cancels all messages. Keep in mind that the 7731 works on several different Panasonic systems. Mine is the TA-824. That command works on most TA series (308,624,824) . On the other systems the code would be 700 and your extension, or *700 ext on TD,TDA,TDE,TAW, NCP etc. boxes.
Carl
Jul 02, 2011 | Panasonic KX-T7731 Corded Phone
I need to change the time on my clock - Panasonic KX-T7730
There are a few types of phone sytems that work with the kxt 7731. these instructions should handle most of them.
Changing the time on a Panasonic KX-TA624 system must be done from extension # 101 using a display phone. All others can use any display set.
1.- Press the "PROGRAM" button on the face of the phone
2.- Enter programming mode by pressing "STAR" - "POUND" - "1234" (default password = 1234)
3.- Enter program # 000
4.- Press "SPEAKER" button
5.- Press "FORWARD/DND" button to change to the hour selection
6.- Press "TRANSFER" button and enter the hour
7.- Press "FORWARD/DND" button to change to the minutes parameter
8.- Press "TRANSFER" button and enter the minutes 9.- Press "FORWARD/DND" button to change to the AM/PM parameter
10 Press "MUTE" button to select AM or PM
11.- Press "STORE" button (listen for 1 tone if procedure was executed correctly / 3 tones if procedure failed)
12.- Press "HOLD" button
13.- Press the "PROGRAM" button on the face of the phone
Nov 02, 2009 | Panasonic KX-T7730 Corded Phone
Simplify the changing of the timeon the Panasonic phone KX-T7731
Changing the time on a Panasonic KX-TA624 system must be done from extension # 101 using a display phone. All others can use any display set. 1.- Press the "PROGRAM" button on the face of the phone
2.- Enter programming2.gif mode by pressing "STAR" - "POUND" - "1234" (default password = 1234)
3.- Enter program # 000 4.- Press "SPEAKER" button 5.- Press "FORWARD/DND" button to change to the hour selection 6.- Press "TRANSFER" button and enter the hour 7.- Press "FORWARD/DND" button to change to the minutes parameter 8.- Press "TRANSFER" button and enter the minutes 9.- Press "FORWARD/DND" button to change to the AM/PM parameter 10 Press "MUTE" button to select AM or PM 11.- Press "STORE" button (listen for 1 tone if procedure was executed correctly / 3 tones if procedure failed) 12.- Press "HOLD" button 13.- Press the "PROGRAM" button on the face of the phone
Nov 02, 2009 | Panasonic KX-T7731 Corded Phone
Changing time
Panasonic KX-T773 reads "102:" instead of date/time
Your extension reads 102 because that is the extension #.
Press either the tranfer key or the " * " star key and your display will change to time and date or just the date.
Oct 28, 2009 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7235E Display time
press Program, **, 1234, 000, (change date & time), store, lift handset
Apr 02, 2008 | Panasonic KX-T7433B Corded Phone
Time and date
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Mar 30, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
121 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
