Question about FIC P4M-800T Motherboard
Upgrade to ram
I just got 2 x 1gb pc3200 400mhz ddr dimm to go onto my p4m-800t motherboard.i have 2 x 512mb pc2700 333mhz already,so i change the two 1gb for the two 512mb but the system only said there was 1 gb,i rebooted the system then it wouldn`t boot up and a bleeping started for the tower.i switched off them put back in the two 512mb and every thing is back to normal.i have no idea
  • 2 more comments
  • Red1989 Mar 19, 2008
    it`s from ebay,a mate got it for me,by the sounds of this he may become a late mate,if i install 1 stick by itself it seems to work ok
    yes it`s from ebay,a mate got it me,by the sounds of this he may become a late mate.
    if i install 1 1gb stick it seems to work but not tested for a long time
  • Steve Carpenter May 11, 2010
    Shouldn't be an issue, this board supports PC3200 up to 2gb.
    Did you but the new memory from ebay by any chance?
    erch.
  • brian c
    brian c May 11, 2010
    What happens if you only install one of the 1gb sticks by itself?
  • 4,102 Answers
Hi if you goto www.crucial.com
this will then scan your system and tell you exactly what you can and cant have give it a try you will find out everything you need to know.
Let me know if you get onto the site ok but i have had no problems
Posted on Mar 19, 2008
  • 88 Answers
It's probably high density memory, it's a common problem amongst bargain hunters. There's more about it at the link below:
eBay Guides - Myth Low Density vs High Density memory modules
You'd be better off getting your memory from somewhere such as ebuyer or microdirect.
Hope that helps. Please remember to rate this solution if you found it useful. Thanks for using FixYa,
erch.
I have 266 mhz 256MB RAM with intel D845 board. I want to upgrade it to 512mb or 1GB. Can you please tell me whether 333/400mhz will be suitable or where can I get it in hyderabad
hlo hyn you should get RAM 200/266 MHz of 512mb or 1Gb
below are the specifications your motherboard can support.
  • Two DIMM sockets supporting 2.5V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
for more info click this link http://www.intel.com/support/motherboards/desktop/d845gbv/sb/cs-012820.htm
Aug 18, 2011 | Intel D845GBV (BOXD845GBVL) Motherboard
Hi..i have a P4m800-M7 rev 3.1 motherboard which recently had only 1 512MB DDR 400mhz RAM.. itried to install an additional 256MB DDR 400mzh ram but the system recognizes only the 512MB RAM. I've tried...
Check that your memory is supported, according to Biostar documentation for your motherboard:
Single Channel Mode DDR2 Memory
Registered DIMM and ECC DIMM is not supported
Re-check the memory module's specifications.
Nov 03, 2009 | EliteGroup P4M800-M7 Motherboard
I have a intel 845GL motherboard with 1.7Ghz
2 x 184-pin DDR DIMM socket support up to 2 GB
recommended: 1GB x 2 DDR 333
http://www.svbinternational.com/motherboards/motherboard_845_chipset.htm
contact ur system admin/vendor for more details....
Nov 02, 2009 | Computers & Internet
DDR or DDR2
DDR 266 is DDR, not DDR 2 . The 266 is the frequency value in Mhz.
Try having the memory refunded or resell it on Ebay, so that you do not lose your money.
Here is supported memory, many older motherboards do not accept modules of over 512Mb each, ask to the seller:
PC2100 Memory DDR266 DDR-266 184-Pin Upgrade (266MHz) Memory Upgrades
Aug 22, 2009 | Computers & Internet
Install DDR-DIMM PC3200 to MS-6367 MSI
That motherboard was made for PC2100 DDR266. A PC3200 DIMM *SHOULD* be backward compatible. Depending on the density of the PC3200 memory you might have problems. If you have not bought the memory yet I would go with the PC2100 for sure since the PC3200 will give you no speed gains at all and will be running at PC2100 speeds anyway.
If you already have the PC3200 memory then I would say just give it a shot. The worse case scenario is your machine will not boot up with the higher speed ram installed. Assuming you take all the normal hardware upgrade care and do not physically break anything you can test this memory with no harm to your motherboard.
Aug 12, 2009 | MSI MS-6367 Motherboard
Getting POST Error "Beep" message (3 Long); on a Gateway 500SE Desk Top with an Intel (Nimitz 4000792) P4 1.8Ghz CPU . Can't run machine to ascertain BIOS; thus to determine that manufacture's unique POST...
Dear Frind i think your second ram 512MB Have PC400 Buss Speed, I think also *********** board doesn't support PC400 buss Ram, Please try Ram with PC266 Or PC333 Buss speed. Best Regards sumon
Mar 20, 2009 | Computers & Internet
2.4ghz, 128ram, P4, 40GB HD.need to upgrade the system.
According to intel:
1.6 System Memory
The Desktop Boards provide the following memory features:
• Two DIMM sockets supporting one of the following10:
 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with goldplated
contacts, or
 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated
contacts
• Suspend to RAM
And yes, you can increase the hard disk.
Jan 12, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Can you expand the memory on a Systemax Intel SIS651 System
Your motherboard is actually a Foxconn 651M03.
According to your system you have :
512MB DDR333 PC2700 Non-ECC Memory (512MB x 1)
(One stick of 512MB)
The motherboard manual says this:
System Memory
Two 184-pin DDR DIMM slots
Supports PC1600/PC2100/PC2700 memory
Supports 64Mb/128Mb/256Mb/512Mb technology up to 2GB
(This means you can have a total of up to 2 Gigabytes of RAM)
If you upgrade your RAM, you will need to make sure that you get the correct type.
If you want to keep the RAM you have, you will only be able to have 1.5 GB of RAM because you only have two slots to work with. If you want to upgrade to the full 2 GB, you will need to buy 2, 1 GB sticks.
Jul 17, 2008 | Computers & Internet
Which RAM supports
hi!good pm...hope this will help...
check your RAM,look for stickers that indicates your memory speed & capacity (e.g. 512MB PC400 DDR)...if there's no sticker description count the pin,a DDR has a 184-pin DIMM...
googdluck!
Feb 07, 2008 | ASUS P4GE-MX Motherboard
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
FIC P4M-800T Motherboard Logo
130 people viewed this question
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
