Optiarc ad 7530a dvd rw drive
I have a compaq c542ea laptop with the above dvd drive, which the device manager says, windows can't start hardware device because its configuration information is incomplete or damaged. code 19.
  • FairbornBill Mar 20, 2008
    Have a Gateway notebook, installed Vista Premium some time back on top of Vista that came with the notebook. Just tried to play a DVD and won't. The device manager identifies this unit a a CD-R only so obviously Windows screwed up the driver and now cannot read the recovery disk that came with the unit as it's a DVD!!!
    Where can I get the driver? Gateway doesn't seem to help at all
  • Anonymous Sep 23, 2008
    my drive reads and burns dvd but not cds. i tried deleting upper and lower filters but no use. i tried everything such as cleaning the lens.
    Problem Solver:
  • 17 Answers
I have seen this problem many times. 99% of the time this will fix it for you. The first part of this fix is to backup the current registry just in case you need to go back.
Try this. I really think it will fix your problem :)
1. Click Start.
2. Click Run.
3. In the "Open" field type REGEDIT.
4. Click OK.
5. Click "File" in the menu bar.
6. Click "Export" from the drop down menu this will open a new box.
7. Click the down arrow beside "Save In" and select "Local Disk (C".
8. In the File Name field type BACKUP.REG.
9. Verify that under the “Export Range”, that the radio button is beside "All".
10. Click Save.
11. Click the plus sign (+) beside HKEY_LOCAL_MACHINE.
12. Click the plus sign (+) beside System.
13. Click the plus sign (+) beside CurrentControlSet.
14. Click the plus sign (+) beside Control.
15. Click the plus sign (+) beside Class.
16. In the left hand window pane click on {4D36E965-E325-11CE-BFC1-08002BE10318} to select that key.
17. In the right hand window pane select the UpperFilters registry key and press the delete key on the keyboard.
18. Confirm with an OK.
19. In the right hand window pane select the LowerFilters registry key and press the delete key on the keyboard.
20. Confirm with an OK.
21. Click the "X" in the upper right hand corner of the Registry Editor window to close it.
Restart your Computer in order for the registry - fix to work.
Posted on Mar 20, 2008
    Problem Solver:
  • 6 Answers
1. Click Start.
2. Click Run.
4. Click OK.
10. Click Save.
Posted on Sep 23, 2008
    change ur settings to pio mode
    go to device manager and click ide ata/atapi controllers
    then go to primary ide then advance settings
SOURCE:
Optiar dvd-rw ad-7580s
Go to this
website http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/optiarc-dvd-rw-ad-7580s-ata-device-my-dvd-drive/fb3f6aa1-31c3-4f7f-9738-807977a1ea78
and read the article
Dec 22, 2012 | Acer Computers & Internet
Optiarc dvd rw ad-7561a ata device unplugged
Check BIOS for Optical drive. Press F key noted on boot screen to enter. If it's not noted there, you need to check physical connections. Might just need to be re-seated with power disconnected. Re-check BIOS and make sure to save before exiting.
If it is noted in BIOS and Windows still fails to see the drive. Run a thorough virus scan, then boot into Safe Mode by pressing F8 during startup. Go to Device Manager, and select Show Hidden devices under the View tab. Delete all drives and reboot. Windows should say new hardware found and install.
This should take care of the problem if there is nothing wrong with the drive. Replace or seek professional support is not, and good luck
Dec 11, 2012 | Computers & Internet
Sony Optiarc AD-7581A 8x DVD?±RW DL Notebook IDE Drive w/LightScribe Burner is not being recognized and installed.... It shows the error 10 "device will not start" can anyone help?
Try a cold boot. Shut down the computer. Remove the battery. Unplug the power cord. Wait at least five minutes. Start up the computer. If still does not work, go to device manager --> CD/DVD drives. Uninstall the Optiarc drive. Go to Actions --> Scan for Hardware Changes, or simply reboot to reinstall the drive.
Apr 05, 2010 | Sony Optiarc AD-7581A 8x DVD?±RW DL...
My Optiarc DVD RW AD-7530A ATA Device will not recognize discs
This is a common problem and is caused by build up on the disc laser light, you can buy a cleaning disk for it that will clean the lazor light try that first ten if it won't read or even before your option go to windows update and update to the new media player, some of the new updates has stopped dvd players from working. Give thanks to RIAA for this one. And if that don't fix it go to start control panel right click on optical devices and right click on the dvd RW and remove the driver restart it Will detect it again and should ask if you want to look for a new driver for it if it does not look for it or does not detect the device then you have a hardware problem, a bad cable or a bad DVD burner.
Nov 11, 2009 | HP Pavilion dv6000z Notebook
Windows vista updated and now my optiarc dvd rw drive won't work
You will have to uninstall the drive and reinstall again. I think the drivers for the drive is not properly installed. But if all this does not work, then I think you will have to do a system restore.
Best wishes
Oct 29, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
OPTIARC DVD RW AD-7560A ATA DEVICE locked by region My (Acer Aspire 7520 running Vista HP) Optiarc DVD RW AD-7560A ATA Device has stopped working (tries to start but unable to find inserted discs)....
it might be a lens problem , if it was working ok before for sometime then its a drive related issue hardware try changing the drive go to ebay find a cheap one like under 60 bucks , also try checking with drive info tools
Feb 19, 2009 | Acer Computers & Internet
E DRIVE DISAPPEARED FROM LAPTOP (ACER)
this is a known issue check the microsoft website on how to work on this,. look for the part where you need to do something with your registry.
Dec 18, 2008 | Computers & Internet
Computers & Internet Logo
8,544 people viewed this question
Ekse
Alun Cox
