Question about Toshiba Satellite A135 Notebook
Touchpad is not working - TOSHIBA Satellite A135-2386
My touchpad starting to behave erratically this morning. The pointer was not moving in the direction(s) I was moving my finger along the touchpad. Now, it has stopped woring altogether. What can I do? Please help!
  • 1 more comment
  • naynayuhl Mar 24, 2008
    My touchpad just stopped working this morning, for no reason....I have tried everything....trying to navigate the computer without that or a mouse is extremely difficult! I have deleted the driver then reinstalled it. That didn't work...PLEASE Help!!
  • Anonymous Jan 12, 2009
    In the Battery mode my pointer works well but with the AC connected it seems to stall on the screen
  • Anonymous Mar 17, 2014
    How do I make my touch pad move the page up when I move my finger up on the touch pad? It now move the pages in opposite directions than I am moving my finger up or down.
    I have a 6 month old Toshiba Sataelite L75D-A7280 With windows 8.
  • 32 Answers
Hey there... :D
Could you try the Fn+F9 Key to Disable/Enable your touchpad mouse?
Because just now i've experiencing the same problem as you guys... and turns out I can make my touchpad working just by pressing the Fn+F9 key.
Note: if your Fn key is not working try installing Toshiba utilities for A135 called FlashCard, run the program and there will be a dropdown menu at the upperside of your screen...
then click on F9 >> and choose Enable.... Thats It... :)
I hope it also solved your problem... :D
Posted on Apr 27, 2008
  • 58 Answers
Could be the palmrest connector isnt making a good connection inside.Try using an external mouse in the PS2 port to navigate till you figure out the problem.
Posted on Mar 24, 2008
Toshiba Satellite A355-S6935 touchpad problem
That is normal, because the touchpad requires a driver. Windows 7, fortunately, comes with driver installation through the Windows Update.
Simply launch Windows update (Start Menu> type "Windows Update" > hit 'enter'), and select all the updates and hit update. You could also manually do it, by going to Toshiba's website, finding your computer model in the "support" category, and finding the appropriate touch-pad driver. (I believe it would be called "Synaptic Touchpad Driver").
Dec 09, 2012 | Computers & Internet
We have a Toshiba A135 laptop with Windows 7 Home Premium. I would like to adjust the sensitivity of the touchpad, but cannot find how do make this adjustment. Please help.
Hi kipspal2,
You can adjust the sensitivity of the touchpad according to your requirement. Just follow the instructions below:
1) Click on Start.
2) Go to Control Panel
3) Double Click on 'Mouse'.
4) The Mouse Properties dialogue box pops up.
5) In the pointer options tab, under Motion, there will be a slider under 'Select a pointer speed'.
6) Move the slider with your mouse towards 'Slow'. Now you will notice that when you move your mouse, the sensitivity has decreased.
7) Apply the settings and Click OK.
Hope this information was helpful.
Thank you for using fixya,
Arun Zac
Nov 27, 2010 | Toshiba Satellite A135 Notebook
How do you adjust the touchpad on the Satellite L505 Toshiba?
Hi, to adjust the touchpad settings for your Toshiba L505 kindly follow the Step by Step intruction guide on this link,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=Mouse+pointer+jumps+around+as+you+type
You will see several search results, just click the topmost result which says "Mouse pointer jumps around as you type". You will then see a detailed guide on how to adjust touchpad settings. Hope this works for you.
Oct 30, 2010 | Toshiba Satellite L505ES5018 Laptop
Toshiba satellite touchpad much too sensitive - pointer jumps all over
You should have a Program loaded from Toshiba to configure the TouchPad including sensitivity.
Dec 10, 2009 | Toshiba Satellite A105 Notebook
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
When using some of the programs such as MS-EXCEL, the mouse pointer behaves as it has a mind of it's own. It starts jumping up and down and behaves erratically not allowing the control using touchpad. I...
first, try cleaning the touchpad WELL with a cloth damp with windex. If still no good, you should try to remove the keyboard, disconnect and reconnect the touchpad cable that goes to the mainboard.
hope this helps
Mar 09, 2009 | Computers & Internet
Dell Inspiron 6400 PC Notebook-touchpad working erratically,help!
i cant figure out how to turn on the croll for my inspiron 6400 touch pad
Mar 05, 2009 | Dell Inspiron 6400 Notebook
Scroll function on my Toshiba Satellite TouchPad isn't working
I would go to this link and select your device and download the driver/software for your device. Try to reinstall the driver/software.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download&cm_sp=Sitemap-_-Support-_-DriversDownloads
Note:
Fn-F9 is a hot key combination that will enable/disable the touchpad.
Feb 14, 2009 | Toshiba Satellite Pro P300 Notebook
Erratic Touchpad on Toshiba M50 Notebook
if the touchpad is working fine with the battery and if it is not working with the ac adaptor then in this case u can try with the different ac adaptor and still if it does the same thing then uninstall and resintall the toouchpad driver and restart the computer and still if it does so with the ac adaptor then u need to open the laptop chasis and then u need to fix up the power supply connector in the motherboard where the power supply from the ac adaptor is not getting the adequate response from motherboard.
Dec 21, 2008 | Toshiba Satellite M50 Notebook
Toshiba Satellite A135 Notebook Logo
1,308 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
