Question about Canon Pixma MP500 All-In-One InkJet Printer
Can i print the image smaller?
  • When I go to print, can I scale my photo down, percentage-wise...or do I have to do that on my photo program?
  • right now the image takes up the entire page.
  • I can't find an option to do so in the advanced settings, am I missing something?
Thanks for the help! -ashley
    Scholar:
  • 85 Answers
  1. Select the 'Page Setup' tab and under 'Printing Type', select 'Scaled Printing'.
  2. In 'Page Size', select the paper size specified in the application. If you select a size that cannot be selected in your printer, a message will display informing you that the setting has been changed to 'Fit-to-page' printing. Select 'Scaled Printing' again.
  3. In 'Orientation', select the same orientation as specified in the application (either Portrait or Landscape).
  4. In 'Printer Paper Size', select the paper size loaded in the printer. In 'Scaling', the magnification at which the document will print so as to fit exactly on the output paper size will appear as a reference value.can i print the image smaller? - scalled_printing_%28windows%29_6.gif.net/uploads/images/scalled_printing_%28windows%29_6.gif" alt="scalled_printing_%28windows%29_6.gif" class="h_mi" />
  5. In 'Scaling', specify the percentage. can i print the image smaller? - scalled_printing_%28windows%29_7.gif />
  6. Click 'OK'.
Posted on Apr 03, 2008
What is dpi
DPI is "Dots per Inch"
Setting the DPI size to a smaller number or percentage will decrease all items size on the display, while setting the DPI size to a larger number or percentage will increase all items size on the display.
Typically, the higher the dots per inch (DPI), the better the fonts will look. If you set the DPI higher than 96, and you are running a Windows Aero theme, the text and other items on the screen might appear blurry in some programs that are not designed for high-DPI display in this version of Windows. You can avoid this issue by using legacy DPI scaling (Windows XP style DPI scaling) for these programs.
Oct 16, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Why cannon ip3000 can't print in only black and white although I choose grey scale priting?
Not sure of the QUESTION..? Do you want to print colour or black and
white..? Anyway,try this, bring up image , at top left click on Fix , at top
right click on Auto Adjust then go down to Adjust Colour click on and
hold Saturation Slider move to left to remove colour ,right to add colour
go to print and it should give you a black / white image. Remember to
return image back to original colour or image will return to file in b/w
hope this works for you..goodluck...T.C.
Mar 31, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
How do i go about printing different size of photos? they are all different sizes.
There are two basic ways to change the print size of your photos/documents.
1. You can go to file/print or you can press cntrl + p on your keyboard. the print menu will come up. go to properties/features. when it opens, look for resizing options. Under resizing options you will see print at actual size and scale to paper size. Select scale to paper size and list box will activated. Select the paper size to scale to from the list. If you are not familiar with paper sizes then this list introduction should do. The conventional official paper size is A4, half of that is A5, and half of that is A6.
2. other procedure is to right click on the photo/image and select print. a print wizard will pop up. it will ask you to chose size of images.
Good luck,
Ryan
Jun 11, 2011 | HP Deskjet D4160 InkJet Photo Printer
Need to change my print size on my C6280 Photosmart All-in-one printer, make it larger
It depends on what you are printing, but generally this needs to be adjusted in the software you are using.
If you print pictures or photos, you have to find an option to scale the printout up, either during printing, or beforehand.
If you print PDF documents, in the Print dialog box there is an option to "fit printer margins" or "auto-adjust to printer size" or something to that effect in every PDF reader application. If however the document is formatted for your paper size it will not be scaled, and if it's formatted for an even bigger sheet size, it will scale down the printout.
If you print documents from Word, there's no easy way to make the printout bigger - you can change the font size to a larger one in the whole text, but chances are, that this will ruin the text formatting.
In Excel there is an option to scale everything by a given percentage, which will automatically tile the table into as many sheets as necessary. and then the area will be printed on as many paper sheets as necessary to get
There's no one solution, unless your printer driver has an option to do a fixed scaling - but this will usually be sensible only for enlarging printouts that occupy a smaller area on paper, and you want them to use the maximum paper area. I'm sorry, but you have to experiment a bit to get the hang of it.
Nov 12, 2009 | HP Office Equipment & Supplies
The images are too big.
go to the printer perference or setting on your pc, there is option says scale to fit the page, click it , and some of printer allow you to select the paper size you are using. its simple problem its just driver setting issue.
Good luck
Mar 19, 2009 | Dell Office Equipment & Supplies
C6180
load the paper in the tray
go to file menu then page setup.
select HP all-in-one printer
choose the paper size, orientation and scale percentage
chick ok then choose print from the file menu
configure the print settings suited for your project.
click print
make sure that you choose the correct paper type before you click print.
Nov 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
Fat percentage question
Some body fat percentage levels are more culturally valued than others, and some are related to better health or improved athletic performance. Ideal percentages are also based on age categories as well. The recommended amount for women is 20-25% and for men is 8–14%. You can find a more detailed body fat percentage chart at your local dietitians and nutritionists, and on the internet.
Aug 27, 2008 | Detecto 8450 Low Profile Digital Pediatric...
How to enlarge print on copier
To enlarge or reduce a printed document by specifying a percentage, select 'Scaled Printing'.
Access the printing preferences by opening the printer Properties/ Preferences.Click here and follow instructions in this document.
Mar 24, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Small print
Turn off and unplug the printer from its electrical source for several minutes. Turn off the computer. Turn on the printer boot up the computer. Try to print something. Try checking for viruses or spyirus http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=257&modelid=11993 this is the site for your printer. Scaled printing To enlarge or reduce a printed document by specifying a percentage, select 'Scaled Printing'. You cannot use this setting with borderless printing. 1. Access the printing preferences by opening the printer Properties/ Preferences. For Windows Vista * Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'. * Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears. For Windows XP Home Edition * Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.' * Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears. For Windows XP Professional Edition * Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.' * Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears. For Windows 2000/Me/98 * Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.' * Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears. 2. Select the 'Page Setup' tab and under 'Printing Type', select 'Scaled Printing'. 3. In 'Page Size', select the paper size specified in the application. If you select a size that cannot be selected in your printer, a message will display informing you that the setting has been changed to 'Fit-to-page' printing. Select 'Scaled Printing' again. 4. In 'Orientation', select the same orientation as specified in the application (either Portrait or Landscape). 5. In 'Printer Paper Size', select the paper size loaded in the printer. In 'Scaling', the magnification at which the document will print so as to fit exactly on the output paper size will appear as a reference value. 6. In 'Scaling', specify the percentage. You can select from 20% to 400%. 7. Click 'OK'. Let me know what happens. Good Luck, Tim
Mar 15, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
113 people viewed this question
old marine
old marine
