Question about Jabra BT350 Bluetooth Headset Headset
Ear piece how do you connect your cell phone to the ear piece?
    Problem Solver:
  • 5 Answers
Hi Snuggle ,
It depends on kind of cellphone you have. Normally there should be an option of Handsfree in the phone settings. choose bluetooth device it should detect the handsfree from there . connect to your earpiece from the list of devices.
for Example : I have Sony Ericsson W700i
I have that option under Main menu -- > Settings --> Calls --> Handsfree
Hope this is Helpful
Posted on Mar 19, 2008
Cant connect bluethoot
If you are trying to hook up a blue tooth ear piece. You have to put the ear piece into discovery mode. See the instructions that came with the ear piece for how to do that. Then put your phone in discovery mode so they find each other. Then you will have to know a pass key and enter that into your phone. Most blue tooth pass keys are 0000 or 1111 or 1234. hope this helps FixYa up.
Aug 28, 2011 | Cell Phones
Bold 9000 only rings through the ear piece when it is connect. Does ring when disconnected to ear piece. When ear piece is not in my ear, I can not hear the phone ring.
Hi, what makes it when disconnected to ear piece. When ear piece is not in my ear, you can not hear the phone ring is because the ringer of the phone that makes you know when there is an incoming call on your cell phone or a message alert tone on your cell phone is damaged and does not work and makes sound to notify you .
The ringer is a tiny speaker inside the cell phone that allows you to hear incoming call from your cell phone You will need to replace the ringer inside the cell phone ....
When you replace with another ringer (speaker inside the cell phone),phone will be Ok again.
Would advice that you contact an expert in phone repairs for asistance,that will do you good to prevent more damaged on the phone...
Take care.....
Feb 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
Can't hear throu ear piece. Only on speaker phone
That's a common problem.It may not be the problem of your ear piece.Try to use it on other phones.If it works then there are two possibilities
1.your ear piece socket is not working
2.your phone is not recognizing the ear piece.In this case reinstalling the firmware (from any service center) of your phone fixes the problem.
May 04, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
EAR PIECE REPLACEMENT
How to check and correct a bad Ear Piece
Equipments Needed
Digital and Analog Meter
Procedures to Follow
Step 1: Check and read your ear piece to see if it's good
Step 2: Check if the terminal is connected on the board interface.
Step 3: If it is not connected, clean well and make it connect.
Step 4: Read the board interface to see if it is reading continually, if it isn't, loop for sound.
Step 5: If it's a flip up phone and the phone interface is not reading, you have to replace the flex to obtain sound.
Take care
Apr 17, 2010 | Samsung SGH-D900 Cellular Phone
Hi, I Have a w995 & the ear piece volume is low.
check around the ear piece, make sure that rubber piece is there and properly placed around the ear piece.
regards
Mar 29, 2010 | Sony Ericsson Walkman® W995 Cell Phone
EAR PIECE REPLACEMENT HELP NEEDED PLEASE INSTRUCTIONS IF POSSIBLE
Equipments Needed
Jan 11, 2010 | Nokia e65 Cellular Phone
Ear piece on my lg lx 350 won't work, how to reset or fix
hi im josh in cebu phils. if you ear piece wont work. friend it is a very simple problem the most reason why ear piece wont work is due to lost connections and covered with dust. try to clean and tighten the connections of the earpeice so that it will work. good luck.please vote me so that i wl know if i helped you.
Feb 23, 2009 | Cell Phones
Brought new phone and need to connect ear piece
You will need to pair it with your phone. first make sure the headset is off, then put the headset in pairing mode by pressing and holding the answer/end button until a solid blue light appears. then you will need to goto your cell phones bluetooth menu, turn your bluetooth on, then in your bluetooth menu you will need to add a new device or discover a new device depending on the type of cell phone you have. Your phone should find the jabra ear piece if it's in range of your cell phone and will ask if you want to pair with the device, after accepting confirm with the pin of 4 zero's.
Feb 16, 2009 | Jabra BT250 Consumer Headset
Panasonic EB-VS2 has no sound
your ear piece needs to be replaced or either replace the flexi from the ear piece with a new one.normally flexi gets damaged .and the last resort is to make direct connection of negative and positive terminal with the ear piece components.
regards,
Imran saeed
manileo@hotmail.com
manileo2001@yahoo.com
CELL: +92 334 5486 094
Apr 19, 2008 | Cell Phones
Nokia 2310 car symbol
check the charging socket and wash . view pictur check track
Sep 23, 2007 | Cell Phones
Jabra BT350 Bluetooth Headset Headset Logo
95 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
