Question about Refrigerators
Top freezer GE refrigerator GTS17KBSERWW
Fresh food compartment doesn't cool
  • snuffhunts Mar 20, 2008
    I checked the vents before I asked for help. They are clear. The fan is running most of the time. Does the defrost problem mean we need a repair person?
    I really appreciate your quick response.
  • snuffhunts Mar 25, 2008
    Thanks, but your solution of turning off the fridge to let ice melt in the vents worked just fine. My problem is solved.
    Thanks so much
    Snuffhunts
  • 52 Answers
Check to see if the vents between the refrigerator and freezer are blocked. Or check to see if the fan is running (the evap fan motor in the back of the freezer) You may have a defrost problem if the vents aren't plugged.
Posted on Mar 20, 2008
  • Anonymous Mar 25, 2008
    No, not if you know how to use a multimeter. Pull the panel off that is located on the INTERIOR back of the freezer. If there is a large amount of ice there, you know you have a defrost problem. If this is the case, do the following:
    Check the defrost heater and the defrost thermostat (both located behind the back panel inside of the freezer). If one of those doesn't show continuity, it is bad. Otherwise, it's the defrost thermostat, or defrost control as it's called on your model. I have posted pictures of all of them below to make them easy for you to identify. The defrost control is usually located under the front of the unit.
    Sorry it took so long for the reply, was busy over the holiday weekend, but please let me know if you need any further help.
    Click here to see the defrost heater
    Click here to see the defrost thermostat
    Click here to see the defrost timer/defrost control
SOURCE:
What else can I check - my fresh food side of fridge is still too warm, freezer fine.
GE refrigerators use a board to control cooling and defrost functions. The fresh food compartment also utilizes a motorized damper, and some models even have a fresh food fan. Air enters the fresh food compartment at the top left corner, and the return air is also in the left wall down near the crispers. Both paths must be clear.
Jul 21, 2014 | GE Refrigerators
Freezer temperature working fine fresh food
I need you to confirm that your model number is ZICS360NR and I will help you, Sea Breeze
Nov 13, 2009 | GE Monogram ZICS360NR Bottom Freezer...
Bottom of fridge not cooling
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 29, 2009 | Estate Model: TT16DKXSQ Top Freezer...
Left door open while cleaning out refrigerator and top unit shut off freezer is still on what should I do
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Aug 27, 2009 | Sub-Zero 650 / O Bottom Freezer...
Coils keep freezing up its 4 years old
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bough a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 30, 2009 | GE GSS20IEP Side by Side Refrigerator
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Top refrigerator not cooling--freezer icy
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
Jul 28, 2009 | Refrigerators
Fresh food side warm. Freezer works fine.
I think you are short of refrigerant, needs to be topped up and checked for leaks.
Mar 03, 2009 | Samsung RS2534 Side by Side Refrigerator
GE top freezer refrigerator
The air flow vents must be blocked. The refrigerator cools from the freezer through those vents, it does not cool independently. They may be clogged in the case with ice. Turn the fridge off and leave doors open for a few hours to let it thaw and it will probably start working.
Mar 19, 2008 | Refrigerators
Fresh food compartment not cold, light is lit when door closed
Engwah, is this the correct model number or does it start with PSS. The light should do just the opposite, off when the door is closed and on when the door is open. This could be part of the non cool problem. If this model has the mother board wich controls the refrigerator it is very possible that the defective fan motor has damaged the motherboard. This is very common in GE refrigerators. The technician will have to run some tests on the board to eliminate it...Catriver..post back.
Oct 28, 2006 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
