Question about Samsung (sw 252 frns) CD-RW Burner
Help//Im a newbee at this...
I need to reinstall my cd-r/rw sw-252 F... its not located on my computer, and I don't have the installation cd for it, what do I do?
  • rosebud168 Mar 25, 2008
    same problem here. i don't have the installation cd for my samsung cdr/rw sw-252b sound driver anymore. what must i do? please help. i'm no techy person. thanks.
    Novelist:
  • 104 Answers
If you run windows xp you dont need any cd just connect it propperly
Posted on Mar 20, 2008
6ya staff
SOURCE:
Samsung sw-252 driver
I've never needed any drivers for CD/DVD Drives, Generic ones by MS normally get the job done BUT here is all that is available from Samsung: http://www.samsung.com/us/support/owners/product/SW-252S mainly firmware updates.
Apr 13, 2013 | Samsung SW-252 CD-RW Burner
My pc have SAMSUNG CD-R/RW SW-252S installed in it and os is window xp. my cd driver neither can read or burn any cd. i ran microsoft fix-it. it fixed reading problem but could not solvr the burning...
Rony, it sounds like your CD drive is dead or dying. Or, you might be running on low power. Did you add anything new, like a new video card, or anything else that would draw power to it?
Aug 28, 2011 | Samsung (sw 252 frns) CD-RW Burner
Totally missing from computer.
make sure that the cd-rw burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rw burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 05, 2011 | Samsung (sw 252 frns) CD-RW Burner
Can get my Samsung SW-252 to open and close but my computer isn't showing that i have a cd drive at all, not sure what to do...and my normal tech is on vacation...
The drive has power but either a dead data cable (IDE), a loose data cable (on one side or the other) or a bad connector (either on the motherboard or the drive).
The most common is the loose cable. Open the case and make sure it is firmly connected to the motherboard and the drive. This can be a pain since the motherboard IDE connector could be hard to reach due to other components. Also, you may need to slide the drive forward in the cage to be able to reach - depending on your case this could involve removing the screws and then replacing them after sliding the drive back.)
If that doesn't work, then try a new cable. One IDE cable can connect to two different devices; most computer builds have only one drive on a cable. Make sure to match the colors or labels so that you maintain the correct master/slave/motherboard connections. The last option is to replace the drive with a new one.
I hope this helps.
Jan 23, 2010 | Samsung SW-252 CD-RW Burner
Lost the install floppy for my SW 208 CD-RW.
I would go to www.samsung.com website and enter in your model number.
Nov 16, 2009 | Samsung (SW-208) CD-RW Burner
Need to find drivers for sw-252
You can get firmware updates here, Is this what you're looking for?
Oct 06, 2009 | Samsung SW 252B CD-RW Burner
Could you give me the copy of this driver?
Try this driver: http://www.samsung.com/us/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=SW-252&dType=D&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=SW-252&isEqualsY=
Apr 30, 2009 | Computers & Internet
CD-RW drive won't open
stick a straight paperclip into the tiny hole in front a few times. This manually rotates the gears and will eject the cd tray.
If it does not still come out because of the jammed CD - you may need to use force!!
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 08, 2009 | Samsung (sw 252 frns) CD-RW Burner
Bnjvb
haaaaaaalloooooooooooo
Jan 09, 2009 | Samsung SW-252 CD-RW Burner
I need the driver for samsung sw-252 CD-RW Burner
May be there are some cable fault. Just check that the cable CD-RW to Motherboard and the power cable from SMPS attached in CD-RW is ok. Then try. If it works then fine. If not, then just format C drive(Or where u have installed the OS). Coz I've already gone through a problem like this. In that case the cables ware ok. Then I just format the C drive and install a fresh copy of XP. And works fine till now.Let me know the result.
Dec 11, 2008 | Samsung SW-252 CD-RW Burner
Open Questions:
See all Samsung (sw 252 frns) CD-RW Burner Questions
Samsung (sw 252 frns) CD-RW Burner Logo
111 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
RONALD CARTER JR
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
