Question about Kitchen Ranges
Black ceramic top
I brought and been using my electric smooth top for a month and I notice it has a fade spot I have used weiners cleaner and
top is smooth but the fade its stiil there any suggestions to help me
  • 788 Answers
They have special cleaners for smooth top ranges to works wonders. Ask at Sears or Home Depot.
Posted on Mar 20, 2008
  • 406 Answers
Donot use anything try bleach/ clorex or clorox
may be it will reduce . The spots are the re or its just a shade
  • Rafique Mannasaheb Mar 20, 2008
    I am online you may chat as well
    If nothing works leave it.
How do I remove black marks from the ceramic cook top
By using the proper ceramic stove cleaner I use Affresh My have to use some elbow grease
May 30, 2014 | Maytag MER6772 Gemini Electric Kitchen...
We have a CCE3401 Jenn-Aire Ceramic Cooktop. I was making jelly this week when I had a bad boil over. We used recommended products to clean up. It has left a black smooth spot above front left range...
Sorry to read about your problem, I hope this helps you out.
try using an oven cleaner spray... let the range heat up a little..then spray oven cleaner
a new glass top will cost over $600.00 just for the glass.
I have tried to help you. Please help me by vote/rate the response. Thanks If you live in the Denver Area. I can help you out.
Dec 15, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Discoloration on ceramic top
Hi- High temps make for tricky maintenance of glass or ceramic tops. The heat element must pass its heat energy through the glass or ceramic and into the pan. Water droplets will steam away, while a spatter of oil or even a few grains of sugar will melt and burn to a tough film of carbon on the surface. The obvious preventitive measures of checking pan bottoms thoroughly before contact with clean (yes- very clean) cooktop surface mean most spots may be small, they can be annoying to look at and tough to remove. My best cleaning results for these spots came from using a VERY small amount of OVEN cleaner (use gloves) on a paper towel placed on spot for a few minutes. A clean, new razor blade may be used to scrape off film. Hope this helps. - Thanks- ED
Feb 25, 2010 | Kitchen Ranges
I have an electric range with a ceramic top. How do I clean it? There is bubbles on the ceramic too, is this from overheating? How do I get those off?
the main killer of glass cooktops is fuses with the top and you cannot get it off. the best way is a razor knife scrape it at a 30 deg. angle. there are some cleaners made for smooth tops as well.good luck!
Jan 23, 2010 | Ovens
I used the wrong cleaner on my Pegaus black vanity top. Now it has spots on it. Is there any way to fix this?
You may have etched the surface with the cleaner, but let's hope not.
Go to your local auto parts store and get a can of Polishing Compound - NOT rubbing compound...this product is used to remove surface blemishes from paint and other smooth surfaces. Try it on a small area only. If it works, you can use it remove the other spots. You can then use an automotive car wax to protect the vanity top....I like Nu-Finish...great product.
Dec 06, 2009 | Pegasus Technologies Pegasus Black Glass...
I had a 2inch by 2 inch black grease stain from a cast iron pot on my ceramic cook top. I used whirlpool cooktop cleaner and a razor blade to try to remove the black gunk. The more I used the cleaner and...
You could try a little oven cleaner on it. That should take care of the mark. After that, if it did not work, clean off the oven cleaner well and then try a bleach solution.
Post a comment with your progress.
May 03, 2009 | Kitchen Ranges
How to remove burnt grease, fix lightly scratched black stovetop?
Hi, I assume we are talking about a flat glass top. First the bad news. using any abrasives will permanently scratch the glass hence the dull spot. You can however make it look a little better. Grease spots and the like can be removed with a flat razor blade scraper which needs to be held flat to avoid the corners making scratches. Use any good glass/ceramic cooktop cleaner ( which is the ONLY cleaner you should ever use ) (available in your local grocery diy store and some hardware stores). The cleaner is a thick liquid, put about a dime size drop on each burner area and use a paper towel to buff out the finish like waxing a car. Once it looks clean flip your paper towel over and shine the top to like new. Good Luck!
Jan 28, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
I bought a Frigidare 30" Freestanding electric range model # FEFL79HB in July. I really like the flat glass top but have had problems trying to clean spills off of the top. Residue from cooked food...
Scotch brite has your solution they have a kit for cleaning ceramic cook tops ..
cook top cleaner kit
go to
there is also a coupon you can print out.
let me know if it works for you just like it did for me..
Sep 09, 2008 | Frigidaire Kitchen Ranges
Cleaning the top
You can use a straight edge razor blade to scrape these areas. A good paint scraper with a wide blade and long handle works best. When done scraping, finish with a good cooktop cleaner.
Jun 01, 2008 | Maytag 30" Built-In Single Electric Wall...
Whirlpool Oven, Ceran stove top
I want to say that since I posted my original problem with black spots appearing on the Schott Ceran top, I took pictures of the top and attached them to a complaint sent to Maytag. Approximately 3 days later, a Maytag representative phoned and offered a brand new top-basically stating that there is a fault with the tops. They would not pay for the labor to replace the top. My husband downloaded the instructions from Maytag website and installed it himself. These spots actually appear from within the surface and are not the result of a boil over, etc. The spots on my burner grew to the width of the burner. If you search the internet, you will see many others with the same problem with the Schott Ceran tops. I will never buy another!
Nov 20, 2007 | Cooktops
Kitchen Ranges Logo
144 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
