Question about LG Televison & Video
My LG LRY-517 DVD/VCR freezes while playing a DVD. It will just freeze the movie, leaving only a still pic. It may or may not start again. This has been increasing in frequency over the last few months. What is the solution to my problem? Thanks Mark
  • 286 Answers
SOURCE: movie skips and freezes during play
This is a common problem on CD and DVD players.
Altini is correct to a point. You can try taking the top case off, removing the DVD drive and taking the top off of the drive. Then use a q-tip on the laser lense. I use a little squirt of windex on the q-tip. Gently clean the lense even if it doesn't look dirty. Make sure you very gently work the lense up and down through it's travel. This will make sure no dust or dirt is interfering with the lense focusing.
Reassemble and try your movies again. This is a 50 50 proposition. If you still have the same problem, the mechanism has likely gone bad. Time for a new DVD player.
Posted on Feb 14, 2008
  • 5 Answers
SOURCE: My dvd player freezes when I view rental/bought movies
Is the player new? If it's a new DVD player and still under warranty, I would return it, exchange it or possibly, consider changing brands: perhaps to a Phillips brand DVD player. After all, the Phillips corporation guarantees its DVD players will play everything, just read the box in which the player's packaged - it's the best bang for your buck. With DVD players being so inexpensive these days, the best option is to buy new. Keep computing Chomskyites.
Posted on Jan 12, 2009
  • 814 Answers
SOURCE: DVD player plays 10 minutes and then freezes screen.
You may have a problem with the transport of the dvd laser. Open the compartment that you place the dvd into. You will see the spindle,the laser lens and the transport device that moves it during operation. The transport system operates on system of gears and drive rails. You must check and clean the drive rails and gears. Use a can of compressed air and blow all the dust and debris from the dvd compartment. Then use some cotton swabs with a small amount of isopropyl alcohol on the tips and clean all the rails and gears. Check the transport action by moving the transport to its most outer position and back to its most inner position. The action and travel of the transport on the rails should be smooth and easy. The gears should be clean and move easy also.These parts will require cleaning every month or so . Remember do not touch the laser lens with your hand. You should also check the lens it should look bright and shine. If not try cleaning it with a cotton swab and a small amount of alcohol. Rub the lens gently back and forth unit it is bright and shines.Now you can try playing a dvd and see if the player works properly. If this does not fix you problem. You can reset the dvd player to the factory settings.1.Press the setup button on the remote control.2.Use the left and right arrows to highlight the preferences page.3.Press enter to to enter the preferences sub-menu.4.Use the up and down arrows to find the default function and press enter. You now have reset the dvd player to factory settings Now again play a dvd to see if the player is functioning normally. If not you may have a more serious problem with the drive motor or power supply circuits. you can call Insignia customer service support at this telephone number.1-877-467-4289. Give them the model number of you dvd player and tell them the problem you are having with the loss of operation during the playing of a dvd. They will be able to tell you how to get testing and service for you dvd player. I hope this information helps you with your problem.
Posted on Jun 03, 2009
SOURCE: Can the LG LRY-517 pick up local digital TV
Called manufacturer
Posted on Oct 13, 2009
SOURCE: i need a part number for an LG DVD, model. lry-517
Are you still a blond ??
Posted on Jan 30, 2011
I HAVE A LG HT506 DVD PLAYER AND WHEN I PLAY ANY DVD IT PLAYS FOR A SHORT TIME THEN THE PICTURE FREEZES . IF I LEAVE IT FOR A SHORT WHILE IT STARTS PLAYING AGAIN THEN FREEZES ONCE AGAIN CAN YOU HELP...
By your description it sounds like the DVD player needs to be cleaned. You can purchase a CD/DVD cleaner at most places like Walmart, Target, or Radio Shack.
Try cleaning it first. If that doesn't work, it will probably have to be repaired by a professional, if it's not under warranty.
Jul 13, 2011 | LG HT503TH Theater System
LG DVD player. Playing DVDs (even new out of the box movies) the picture freezes for between 10 sec - 60 secs. DVD has hardly been used since new and I have used a lazer cleaner on the DVD tono effect.
Try to clean the lens of your player and the cd.If they freezes again,Maybe the lens of your DVD player have not good enough its better to replace lens
Jul 11, 2011 | LG Televison & Video
After warranty time expires (2yearsd) my LG LRY-517 DVD combo recorder/player start to make randomly disc reading errors. During half year things has going worse. Now the situation is that it does not play...
Use lens cleaner disk to run many times. It cleans the lens and also runs cd on the disk which eventually will get rid of moisture on the circuits and restore your dvd recorder on the LG unit.
Mar 11, 2011 | Televison & Video
Does this model DVD/VCR recorder have an analog tuner or a digital tuner?
Is there a manufacture date on the back of it. The Commission's digital tuner rule specifies that as of March 1, 2007, all new TV sets must include digital tuners. I believe that rule follows when it comes to DVD players with built in tuners. If you bought this before that date then most likely its analog. I see in the owners manual has no listing for a digital tuner. So I would come to the assumption that its analog tuner. Hope this helps!!
Jan 14, 2011 | LG LRY-517
Have LRY-517 dvd recorder and have used it maybe half a dozen times. Now it will not let me initialize any discs. Gives me " Unknown disc, check disc again" error everytime.. Cleaning the unit inside and...
Normally, I'd advise cleaning the IR lens with a disc-based lens cleaner, but at only six uses, the problem could be controller board or misaligned laser/lens assembly.
Could be something worked loose or skew disc jammed in drive.
Have you tried DVD's from just one pack, one type, or other types?
Why I ask - I had this problem on my PC's DVD-writer.
It turned out that a full (new) pack of DVD's was faulty.
As a test, try initialize same (suspect) disks on another recorder?
Oct 05, 2017 | LG LRY-517
Unable to play some new dvds
I'm having the same problem with my LG as well. In fact I tried playing Transformers as well (on 29 Dec, 2007) and it froze mid-way as well (somewhere in scene 9). I was thinking to call the manufacturer but if they don't know either I'll take it back to the shop and replace.
If any of you have found a solution though, would much appreciate if you could share. Thanks.
Dec 09, 2007 | LG LRY-517
Freezing
Probably needs either a cleaning or a new laser picup assembly
Dec 19, 2006 | RCA ® 700 Watt Home Theatre In A Box...
Televison & Video Logo
61 people viewed this question
