KVM Switch I have two HP Compaq Presario Computers that I would like to connect to an HP All-In-One Printer using a KVM Switch. I have tried Networking the Computers to do this but it does not work. At the present I am using a D-Link EBR 2310 to get both an internet connection.
  • 655 Answers
I don't no how did you try.
If your both lap are connected in any way you can share printer to both your lap. Please try the following steps:
Step 1): Install the printer drivers to your first lap.
Step 2): Connect your printer to your first lap and turn it on.
Step 3): Navi gate Start -> Printer and Faxes
It will open the Printer and Faxes window including all your printer installed.
Step 4): Right Click on the printer icon whic you want to share and select Sharing.. from the pop-up menu appeared.
It will open your printer properties.
Step 5): On sharing tab click on Share this printer radio button and give a Share name also tick the list in the directory.
Step 5): Clik on Ok
Now your printer is ready to share to other computer in your network.
Step 6): In the second lap navigate Navi gate Start -> Printer and Faxes
Step 7): Click on Add printer to left panel of the window
Step 8): Click Next
Step 9): There will be option Local or Network select Network and click Next
Step 10) Again Next, The find printer dialog will be open. Type the firs 1 or 2 letters of the your printer name which you have given in share name of first lap and then clik find.
Step 11): The printer will be listed in a list Select and click ok and click on next in next dialog.
and now you can enjoy..........:))
Thanks
Iqbal
Posted on Mar 19, 2008
6ya staff
SOURCE:
Wireless switch for an HP Compaq Presario CQ60-250DX Laptop
Hello
Can you be more specific on your problem?
I figure, if the wirelss switch wont go on, perhaps has to do with any office installation, ...or the botton is broke.
Oct 11, 2013 | HP Compaq Presario CQ70-120US Laptop
Networking with hp 2355
This model printer has only an USB connection and needs to be connected to a computer.
To use this printer on your network, the printer needs to be connected to your computer and must be configured as a shared printer.
Your computer and printer must be switched on at all times for the other computers to print on this printer.
Nov 09, 2012 | HP Office Equipment & Supplies
Have a GCS634U KVM that keeps failing to switch. acts like it lost the keyboard
This GCS634U was designed to work with USB keyboards and mice.
First, you need to make sure that your using a direct USB keyboard (no PS/2 to USB adapter).
Second, connect the keyboard directly to the computer and make sure that it's working correctly.
Third, check the connection between the KVM switch and the computers. Try to connect the USB cables of your KVM into different USB ports of the computers.
Last, try to use different USB keyboard to see if the issue is the KVM or the keyboard.
Try to power cycle the KVM switch. Disconnect the KVM from the computers and make sure that there's no even one cable connected to the computers.
Leave the KVM switch disconnected for 10 minutes, then plug it back in. Reboot one computer first and wait until it's fully rebooted. Turn on the second one untill all computers are fully booted up.
If same problem occur, then you need to contact IOGEAR and have them RMA the device.
Thank you and good luck!
Nov 12, 2009 | IOGear GCS634U KVM Switch
KVM Switch 4110 8 port
so is the KVM (control side, PS2 mouse / kbd>??)
or are all PS2 ports wired to adaptors,? i cant guess this nor what was used before, no history stated.
what was there before, this act?
and what now?
Ill assume worse cases (tossed a coin)
18 (16+2) adapters now. all devices are USB but KVM
ok.?
what mode fails, both the KVM pushbotton switch and or the hot key commands on the kbd?
Oops no manual button as seen on modern KVM.
KVMs are very complex. the hard part is the vast number of different PC.
USB , PS2, VGA, DVI and HDMI.. yah,..
OK 16 +2=18 x ps2, and 9 VGA ports. it is.
NO KVM does it all, ,, old KVM' do NOT work , on new computers, all folks know this , if they tried. or took readings to learn why it fails.
I bet power to the KVM is dead., no LED./
no manual button ,oops.
pin 4 PS2 reads 5vdc and connected up, same?
we use breakout boxes (DIY) to test ports connected.'
that Compaq is very old and no support now, no books.
why not ask at real HP, maybe some old guy there can dig it lost books>
40 KVM? that what you said, really? (or 40/8=5 kvm)?
my guess is the adaptor does not work or power issues
KVM >>PS2>>>ADapt>>> USB.(server) (usb 1,2,or 3 at server?)
The KVM in most cases, here, steals power from PS2 ports but not this KVM , its better.
i'd bet that adaptor cant do that.
(is the caps lock key working on the KBD and laser LED glowing on said mouse?
ask here, real HP.
lets see tests:
1: pin 4 ps2 5vdc?
2: mouse glows?
3: keyboard led , caps lock toggles? (glows)
4: lost the hot key commands (y/n)
one other problem is the BIOS in the server may not like your adaptor at all. When BIOS scans the keyboard. it expects a ID response if missing or grabled, it drops that device port.
https://h30434.www3.hp.com/
btw, one way to cure this, is run headless server software
end KVM for ever.
i run a LAMP server, that comes in the box, no kvm no any thing on ports. it has a web page to go to and do service that way.
port IP+:12321
modern ways work best.
in a server farm, a keyboard/mouse/monitor on rolling cart
for the super sick servers is best...
the other problem is USB only PC or server
does not scan PS2 ports, it has none
so if the adaption fails, at boot time, all is lost.
(BIOS reports connected devices to the OS)(unstated by you)so if the report fails, problems happen
for sure after the boot.
this device is s business device, now ("Enterprise)
the posts on it are like 10 years ago. all links to books now dead.
infact the compaq server that had them is turned off. (grin)
here is my search there. Why not ask them?
https://www.hpe.com/us/en/search-results.html?client=&qt=kvm+4110&search=%EF%98%90&cc=us&charset=utf-8&hpa=http%3A%2F%2Fwww8.hp.com%2Fus%2Fen%2Fhpe%2Fcontact%2Fcontact.html&hpn=Home&hpr=http%3A%2F%2Fh41131.www4.hp.com%2Fus%2Fen&hps=Home&lang=en&qp=url%3Ah41131.www4.hp.com%2Fus%2Fen+url%3ANEW+URL+GOES+HERE
Aug 26, 2017 | Compaq 242695-001 8-port KVM Switch
Hawking HFS5t
Try resetting the switch back to its default configuration. It sounds like you have a routing issue within the switch causing your printer not to be seen by your pcs.
Can you connect a pc to the switch just to see if you can ping your printer from there?
Mar 24, 2008 | Hawking (hfs5t-eu) Networking Switch
HP Compaq Presario V2000 PC drives
There are many Presario V2000 models please use the following link to determine yours. Note there is another link inside for notebook PCs
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00004461&product=89327&lc=en&dest_page=product&cc=us
Hopefully you can find your model in the following link
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-001&h_query=presario+v2000
And your NIC driver will be hopefully available in Software & Downloads after choosing the Windows 2003 operating system. -- if that OS is not present, try another OS and check the operating systems as they appear in that specific driver's supported list of operating systems and see if Windows Sevrver 2003 appears.
Dec 20, 2007 | HP Compaq Presario V2000 Notebook
Open Questions:
I forgot my YAHOO password #{18OO~828O294} phone number usa Anita. There are two circumstances that can cause someone to want to change his/her YAHOO password: 1 forgetting the YAHOO password and needing to recover it and 2 to change the YAHOO password. The latter can be because the YAHOO password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's YAHOO password at least once in a month. Contact YAHOO Mail Password Reset 1-8OO-828-O294. For your convenience to contact YAHOO Mail Password Reset We have provided all possible information of YAHOO Mail Password Reset. You can contact YAHOO Mail Password Reset on the given phone number 1-8OO-828-O294. Changing an YAHOO Password The following steps show in detail how to change an YAHOO password when the current password is known: Sign into the YAHOO Mail Account from YAHOO Do you want to recover/reset your YAHOO email password? So you'll be do the some steps to recover your YAHOO password. We'll help you to fix your problem and we'll guiding the some steps to recover your YAHOO password. Follow and do the below steps to recover your YAHOO email password- Go to the YAHOO - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your YAHOO mail message on your Gmail account. YAHOO is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While YAHOO's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, YAHOO has made it easy to recover or reset your account's password. Please Read If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your YAHOO password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your YAHOO password.
Oct 23, 2019 | Yahoo Computers & Internet
CHANGE password on YAHOO email account #{18OO~828O294} phone number usa Anita. There are two circumstances that can cause someone to want to change his/her YAHOO password: 1 forgetting the YAHOO password and needing to recover it and 2 to change the YAHOO password. The latter can be because the YAHOO password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's YAHOO password at least once in a month. Contact YAHOO Mail Password Reset 1-8OO-828-O294. For your convenience to contact YAHOO Mail Password Reset We have provided all possible information of YAHOO Mail Password Reset. You can contact YAHOO Mail Password Reset on the given phone number 1-8OO-828-O294. Changing an YAHOO Password The following steps show in detail how to change an YAHOO password when the current password is known: Sign into the YAHOO Mail Account from YAHOO Do you want to recover/reset your YAHOO email password? So you'll be do the some steps to recover your YAHOO password. We'll help you to fix your problem and we'll guiding the some steps to recover your YAHOO password. Follow and do the below steps to recover your YAHOO email password- Go to the YAHOO - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your YAHOO mail message on your Gmail account. YAHOO is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While YAHOO's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, YAHOO has made it easy to recover or reset your account's password. Please Read If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your YAHOO password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your YAHOO password.
Computers & Internet Logo
99 people viewed this question
Ekse
Marvin
Marvin
