Question about Ovens
Automatic oven shut off
My oven shuts off automatically after 24 hours - how do i turn this feature off
  • Robert Weir
    Robert Weir May 11, 2010
    Important question here is why are you trying to operate an OVEN for so long? Are you heating the house with it?.
    Also, if it is a safety reason, why would the manufacturer have an override abitlity?
  • Ron Coons
    Ron Coons May 11, 2010
    some newer ovens shut off for safety reasons , most usually allow you to override tis check you manual if you dont have one please let us kn ow what the make and model of your stove is and ill try to find a find the answer for you
4 Suggested Answers
SOURCE:
Powerman
  • 68 Answers
SOURCE: i need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
Posted on May 21, 2007
  • 125 Answers
SOURCE: automatic oven starter-timer
Hi there. If you have an older oven, it most likely does not have a combination valve with a thermopile, not the same as a thermocouple, or a hydraulic safety. If there is a red button sticking out the panel where your thermostat is, you have a hydraulic safety. What you want can be done with wiring, solenoids,timers, and the correct location in the gas line, but would require a bit of modification. I would only use a servicer for this type of modification, if they will even do it, could you find someone to do it, with little concern about safety? sure, but it must be understood, you are taking the risk, and responsibility. This is definitely not a do it yourselfer task.
Posted on Feb 21, 2009
SOURCE: I have a Fagor 5H 196X oven and whenever I set the
Please find here our reply from the customer service of Fagor America:
This problem could be confusion over how to properly program an automatic cooking function. First, you must program the cooking duration, then you must program the time of day you want the food to be ready. Sometimes customers think they need to program a “start time” and an “end time” versus a “duration” and an “end time”. Please, make sure you are doing both steps correctly. Also, you should be aware that this clock works on the 24-hour principle (military time). I know that sometimes this confuses people as well. If both of those are okay, then it probably has a defective clock. If that is the case, please feel free to call our customer service:
UNITED STATES OF AMERICA and WESTERN CANADA: Please contact ADCO Customer Care at 1.877.743.2467, or by email at: [email protected]
EASTERN CANADA: Ontario, Quebec. Please contact A.G.I Service Inc: Telephone: 450-963-1303 or by email at: [email protected].
If you have any other questions do not hesitate to contact us at: [email protected]
Best Regards,
Posted on Aug 23, 2010
Got error "pyrolitic interrupted" any way to clear this swithed of power for 24 hours to no effect
A feature of certain Smeg ovens, Pyrolytic cleaning is an automatic cleaning function which works by heating the inside of the oven to 500°C, at which temperature any grease stuck to the walls is simply burned off.
i think something is wrong with the elements
or a sender / sensor
so as its telling the controller for the oven that its not getting to the right temp perhaps one half of the oven isnt running etc
perhaps some sensor has become worn at these hi temps i cant see a senor lasting more than a few years before it degrades
May 05, 2015 | Ovens
I have an older gas oven/stove top and would like to disconnect the feature that turns oven off after 12 hours
If you have older type gas oven look at the clock and reset so you see manual position. This will remove automatic cycle.
Mar 28, 2014 | Ovens
The oven shuts off after 12 hours. How do I leave it on longer?
Hello, I found this info on the manual for your oven:
12-hour automatic cancel This safety feature prevents oven from continuing to operate if it has been left on for over 12 hours. If a cooking function continues longer than 12 hours without any options on oven control being touched, this feature turns oven off. Any time an option is touched, 12-hour automatic cancel is reset.
If you want to print up your own owner's manual, here is the Amana link. Just type in your model # and then click on the link to read it or print it up
http://shop.amana.com/product_literature/search_results.jsp?searchTerm=AOGD2750&siteCd=AMA&userType=Consumer
May 19, 2010 | Amana AOGD2750 Stainless Steel Gas Double...
Automatic self cleaning turnoff
most newer ovens have to be programmed for how long the unit should clean for. usually need 3 hours to get hot enough to clean the spills. after that it needs another 45 minutes or so to cool down to allow the door to unlock and let you open it.
Dec 31, 2009 | Ovens
Hotpoint Self Cleaning Oven
the oven has a feature where you set the time for it to begin cleaning and the time for it to end cleaning.
Next to the clock in the middle of the back are two dials. The top one is the start time, the bottom one is the end time.
I suggest 2 hours to allow a good cleaning.
The locked light will turn off when the cleaning is done, allowing you to open the locking lever.
Jan 17, 2008 | Ovens
I need to disable my ovens auto shut off
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Ovens Logo
131 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
