Question about Lands Phones
Phone beeps during calls
Phone keeps beeping twice during calls
  • Neal1 Mar 19, 2008
    This phone is a Philips Model CD4450 cordless phone. I originally thought it was call waiting, but there never has been anyone there.
    Neal
    New Friend:
How do you disable this feature? To stop the crazy beep, beep, it's becoming annoying-"Sounds like someone's tapping into the phone.
Posted on Nov 19, 2011
If its a double-beep, its normally an incoming call alert, which you hear when you're already on the phone. Its alerting you, so you can answer the incoming call. If you don't want call waiting, then you can turn that off in your phone's "call" settings.
If its not that, then it may be the in-call alert set to beep for every minute that passes. In your phone settings, you should be able to find this in your "in-call" or "call" settings.
Posted on Mar 19, 2008
  • 3,037 Answers
Depending on the phone, if you just got it, it may beep when you have been on for a minute or a different time, it may beep because you have a message, or it may beep because your battery is low or because of the setting it is on, please post the type of phone if none of these reasons are the cause
SOURCE:
Telular phonecell sx6
This might be being caused by a facility called call waiting
When you are on the phone during a call if someone else rings you will get a beep beep sound to inform you that there is another call coming into your phone.
https://en.wikipedia.org/wiki/Call_waiting
Dec 03, 2017 | Cell Phones
Beeping during calls
Hi!
  • Is it beeping during every call or just some?
  • Is it possible that you have call-waiting enabled on your line & the beeping is another call trying to come through?
    If you think this is the case, call your phone service provider & request it be taken off your line.
  • Try plugging a different phone into the line to determine if the problem is being cause by your phone, or by the phone line.
Hope this helps.
Nov 20, 2009 | Motorola Lands Phones
Kepad beeping while using MagicJack
I have the same problem with the key pad beep during telephone
conversations and I hace a Uniden 5.8ghz phone.
So its not just panasonic 5.8 ghz phones that do the beeping.
Jul 11, 2009 | Panasonic Lands Phones
I have a problem in my phone w850i sony ericsson that when i want to record the call without beep here i want to off beep during the call
the beep you hear during your phone call is a minute reminder meaning a beep will be heard signalling that the call has been going for another minute.
to remove this feature if you find it annoying just go to call settings there should be a setting about minute reminders: make sure it is off.
May 10, 2009 | Sony Ericsson W850i Cellular Phone
check if this a minute beep during on call, you can find it on the menu settings , call settings.
hope this initial info helps you.
micro
Mar 21, 2009 | Samsung Cell Phones
Nokia N72
to record voice memos, press the menu button, and select OFFICE->RECORDER. To record a conversation, choose RECORDER during a voice call. Both parties will hear a beep every 5 seconds while call is being recorded.
May 16, 2008 | Nokia N72 Cellular Phone
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
Apr 28, 2008 | Samsung SGH-E900 Cellular Phone
Unkown Beeping During Calls
It is hard to tell if this conference phone is installed on a PBX or not? "At meetings" tends to make me believe that it is. Beeping can come from a few sources. If a call is being recorded it is necessary to provide a beep tone so that the parties on the line know that they are being recorded. This is a FCC requirement. You can ask the other party if they are recording the call. Beeping can come from call waiting. It is recommended to turn call waiting off unless you are bridging incoming calls. If a call is on hold you will get a beeping tone. You can check by pressing the flash button and see if there is a second call. If so hangup and your original call should return normally.
Mar 21, 2007 | Polycom SoundStation 2W (2200-07800-001)...
Lands Phones Logo
2,391 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
