Question about RIM BlackBerry Pearl 8100
Newly purchased palm tungsten E- turns on by iself and tries to connect to wi-fi, won't let you cancel, and then dies and needs rebooting several times. I have deleted previous programs that were on last palm that I had.
    Problem Solver:
  • 36 Answers
The Tungsten E does not have Wi-fi. It doesn't even have Bluetooth (the E2 has Bluetooth). You've clearly got something on there that belongs to a different model.
There is a program called "Filez" that will let you take a look at each individual program on the device. The ones that are on ROM are marked by a chip. If you find one that is both in ROM and RAM, the one in RAM may be the problem.
Look on for Filez.
Posted on Mar 19, 2008
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
My I-Pad will no longer connect to WI-FI. Any suggestions?
Take to "Genius Bar" in Apple store; they will Dx for free; only charge if repair is necessary!
Sep 27, 2014 | Apple Ipad I-pad
Proxy address for samsung quadpad GT-S5233
1. Go to Menu.
2. Select Browser.
3. It will prompt you to create a new connection. Select Create.
4. In the next section leave Set Name as it is (or you can change it if you like)
5. In Bearer type drop down box Select Wifi.
6. In the next prompt select Search Wi-Fi Manually.
Wi-Fi will turn on and search for a Wi-Fi network in the region automatically.
7. Select the Wi-Fi network you want and It will save its name.
8. Leave the rest of the things as it is, no need to change any more settings.
9. Just select Save Button, It will directly take you to Browser profile page with the newly created profile listed(Default Name: Connection 01). Select the Radio Button in front of it.
10. Now come out to the main menu.
11. Now go to the Wi-Fi Tab, as it is already on it will show you the Wi-Fi networks in the region, if its not, turn it on and search again.
12. Select the Wi-Fi network you want to use and, select Connect.
13. Depending on the signal strength it will try connecting.
14. Once connected it will give you a message saying connected, you might need to attempt it a couple of times.
15. Once connected exit out and go to any shortcut on your phone or select Enter URL and type in the name of the Site you want to browse to.
16. There you go, you can start browsing to all your favorite Sites now.
Jan 05, 2012 | Samsung Star GT-S5233 Cell Phone
My PalmOne Tungsten E2 is stuck on cancelling Blazer
Usually I just hit the reset button and hope nothing was corrupted. Just use your stylus or a pin and press the reset button in the hole on the back/bottom of the palm. It will then reboot and you should have control back. Blazer is pretty stable but once in a while it acts up.
Apr 12, 2010 | Palm Tungsten E2 Handheld
When searching for wi-fi connection palms blacks
This is hard to say what it is for sure but I would think your problem is your battery needs replacement. The wifi works fine with a good battery but uses much more power than anything else so it can quickly drain an older battery. If it is older than a year or so it might be it. I have a lifedrive that will kill a battery within a few minutes on the wifi. When new I could use it for several hours. If you put it on the charger it should work normally if this is the case.
Mar 19, 2010 | Palm TX Handheld
Tungsten e2 wi fi card
this weblink might help you
Easy wireless connections
Bluetooth wireless configuration is easy, quick and intuitive. Use the Bluetooth Manager as a one-stop-shop to configure wireless connections for HotSync, Internet access, text messaging or to dial phone numbers from Contacts.
Synchronize wirelessly
Transfer information from your handheld to your Bluetooth-enabled computer from across the room. Anything you can sync via cable or cradle you can sync wirelessly – Contacts, Calendar, photos and documents.
Send email and access the web1
Browse the web with the Blazer® web browser and access your email with the VersaMail® email client. Simply connect your handheld to a Bluetooth equipped mobile phone, or a Bluetooth equipped laptop connected to the Internet.
Jun 22, 2008 | Palm Tungsten E2 Handheld
Wi=Fi connection
First question is do you have a wireless router connected to your internet, and if yes, you may need to tell your router to broadcast your ssid. Instructions differ on how to do this so check the manual for the router. Hope this helps.
May 25, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Palm T3 frozen, tried restart in hole, nothing?
take the battery off for 15 seconds and put it back again. you need to reboot your Palm at least once a week. goodluck!!!
Jan 31, 2008 | Palm Tungsten T3 Handheld
try a ping test from your router(should be under a status tab or something) and if that works then go to the prefrences, wifi, info(conect first!) edit network, details, advanced then enter a custom ip ie just copy the first 3 sections of the ip address of your router and add a number greater than 1 after and enter your routers ip address for the dns server.
Jan 06, 2007 | Palm Tungsten E2 Handheld
HP iPAQ 3715 - screen problems
Return it as faulty. WiFi should not impact your screens ability to stay on.
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
RIM BlackBerry  Pearl  8100 Logo
71 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
