Question about Dual Presidian DVD Recorder
Finalizing when go to finalize the disc it won't let me, it's locked . has a picture of a lock on it. keeps wanting a new disc
  • Retro-Roy May 11, 2010
    Have you found a solution to this problem? If not, I have the info in my owner's manual that may help. If you have a manual, it's on page 54.
    Roy Davis
Insert disc dont remove
Posted on Mar 27, 2009
My centrios edw8020 dvr records o.k. but won't play dvd on any other dvd systems
If the disc is not "finalized" it will not play on other DVD players. The steps to finalize the disc are part of the DISC Utilities Menu. under "DISC OPERATIONS". Choose "FInalize DISC". Instructions refer to finalizing DVD=R disc, so you may want to try this type of disc first and see if it works. Says It can be used as DVD-Video disc but results are not guaranteed. You can not edit disc after finalizing, only playback.
Jan 28, 2014 | Centrios EDW8020 DVD Recorder
My disks are DVD-RW and want tp use them over gain and don't know how. Also when do I finalise then and what for
For RW discs, you need to reformat them to reuse them. For your laptop, you should see a format option if you right click on the DVD icon when you have the File Explorer open to Computer (My Computer). (This assumes that the computer has a DVD writer.)
Finalizing the disc enables the contents of the disc to be read on other DVD players. (This isn't always an issue. For example, a disc burned with WinXP should be readable for a computer with Windows 7 without finalizing. However, if the disc was burned by a DVD player, the contents will not be accessible on any other units without being finalized.)
If the disc has been finalized, you need to take another step before reformatting the RW disc. Put the disc in the unit that initially finalized it. Then look for an Unfinalize option. Then format the disc again. (I've never used this feature on my computer. It's easily accessed on my DVD recorder in the same section of the submenu as finalizing the disc.)
I hope this helps.
Sep 12, 2011 | Computers & Internet
Finalizing
Use a name-brand DVD, such as HP, Verbatim, etc. and make sure it is a DVD+R or DVD-RW/-R disk only.
It is most likely that the DVD you are using is not compatible.
The disk is still usable, but you can only read it on that player.
Aug 17, 2009 | Funai PY90DG DVD Recorder
Finalizing DVD-R fails, rendering Verbatim disc non-readable
You might try finalizing the disc in a PC using IMGBURN or other DVD recorder software. It couldn't hurt...
tom
Jan 09, 2009 | LG DR787T DVD Recorder
How to finalizing after i recorded
from page 36 of the manual....on the remote control1.gif press SETUP use the arrow key to select "DISC EDIT" press OK Use the arrow key to select FINALIZE press OK. A confirmation window appears, use the arrow to select YES and press OK. If you still cannot view on a different DVD player, you may want to check to make sure that your disc's are compatible with the new player.
Jan 21, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Power disconnected during finalization
There's no way you can continue the finalization of the disc, the disc has been marked as finalized already, even a single power fluctuation when you are using ac power adaptor can affect the disc finalizing process, so it is better to use battery when disc finalizing
Aug 30, 2007 | Sony DCR-DVD301 DVD Camcorder
Finalizing and reading discs
What a load of rubbish this camcorder is and Samsung customer service is a load of rubbish too.
Jul 11, 2007 | Samsung VP-DC161 DVD Camcorder
Unable to Finalize Disc/Finalize Option Blacked Out
I don't know if there is any solution. The Canon DC 210 seems to have BIG BIG problems with finalizing, even for those who are plugged in and in Play mode.
Jun 22, 2007 | Canon DC210 DVD Camcorder
Disc access after finalizing
Get the software IsoBuster. It will analyze the disc and extract the images that are still there.
Jan 01, 2007 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Finalizing vs. not finalizing a DVD-R. DVD-R vs. DVD-RAM?
on standard players. The write all the information that a standard player looks for to read the disk. Nothing is lost if you take the DVD out of the recorder without finalizing it. On a PC, you would tell the software to eject the disk. Later model hardware can usually reopen a disk after it has been finalized. Is this a typo? 'I know that the disc cannot be seen in a DVD player after being finalized'. It should read; I know that the disc can be seen in a DVD player after being finalized
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Televison & Video Logo
131 people viewed this question
Top Dual Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
ray gallant
Are you a Dual Televison and Video Expert? Answer questions, earn points and help others
