Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Rechecked the conections and still
Hi..rechecked everything and no bad connections, etc.. so I have since pulled the entire circuit board assy from the TV chassis and am going to try and troubleshoot from component level. Seems like a short somewhere but not too familiar with this model. I have a service PDF of the model, any suggestions where to start?
Thank you in advance!
-Richard (MetalDad)00000000000000
    Genius:
  • 3,587 Answers
Well..that's interesting...before you begin, have you determined a source for replacement components? I'd be hesitant to do all that work, NOT knowing if there are readily available form fit function components for it. Don't assume that overseas manufactured appliances have a ready distribution system for spare parts.
Posted on Mar 19, 2008
ECHO PE- 200 won't stay running
Check and replace the impulse line if you haven't already. How did you set your carb screws after the rebuild? Start with them lightly seated and then give each a 3/4 turn out to get yourself started.
Mar 17, 2017 | Sewing Machines
''Bad disc'' error when any disc loaded in JVC XV-N670B DVD Player
There may be a connection to the problem, but it sounds like the laser assembly may need to be replaced as well as/or the mpeg printed circuit board(the printed circuit board) attatched to the laser assy. Good Luck.
Sep 26, 2009 | JVC XV-N320 DVD Player
Zero compression on #4 cyl
possible valves---- listen to the intake inlet and exhaust pipe for"POPPING", that will indicate a valve bad, if you have a compressor you can air charge that cylinder and listen for air by-passing....other problem may be the piston is damaged, usually by a leaking injector or ign problem (detonation)...this is major.....hopefully not....hope this helps...GL
Jul 06, 2009 | 1998 Ford Escort
2008 Ford F-250 Low beams do not work. High beams are fine.
it could be Bad dimmer switch .just check out the switch.
Jan 10, 2009 | 2008 Ford F 250 Super Duty 4WD
Im not getting any singnal on my router
check the cable connections..reset the router..otherwise please contact your service provider
May 01, 2008 | Linksys Wireless-G WRT54G Router
Amps and resistors
The IC is no doubt bad due to powering it up with the solder bridge. may possibly need entire convergence board unless you have the service manual and troubleshoot it.
Mar 05, 2008 | Hitachi 53SWX12B 53" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
