Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Slow Everything works fine but the coffee comes out very slowly.Almost drops of coffee. Can you help? Thanks Frank
  • jonesing Mar 26, 2008
    we have a saeco magic combi and everything worked great for about 5 months. now when we pull a shot of espresso the coffee comes out very slowly, with little pressure, and the sound of the machine isn't right when this is happening. (too quiet) The steam works, and the pressure is great when drawing just water, and the sound of the machine is perfect when this is happening. It just won't make coffee anymore. Is there a way to clean the brewing mechanism?
  • 515 Answers
Adjust your grinder to grind coars, when the machine "drip" out the coffee then it is to fine, adjust the grinder two step and then you have to maker 3-4 cup of coffee to make your new tasty coffee;-)
Posted on Jul 11, 2008
SOURCE:
Coffee dropping slow
Too few indications.
Generally coffee ground too fine.
Hope that helps.
M.
Apr 05, 2016 | Saeco Vienna SuperAutomatica Coffee...
Coffe Machine Saeco Magic Comfort
the coffee beans grinder is too fine .Turn to next number,
Oct 29, 2013 | Saeco Magic Comfort Plus Espresso Machine
The coffee is very slow coming out.we have decalcified the machine many many times,taken the grindchute assembly out and cleaned it,and now we are running out of options Please help
Coffee coming out too slow could be a number of problems.
I'd start with the grinder and make sure it is set to the right settings. If the coffee's too fine it will cause the coffee to come out slowly.
Next it could be a dirty brew group. The internal part of the brew group has a glass ball inside of it which is used to during the infusion process. Take the ball out and make sure that area is all clean.
Restrictions in that area can cause the coffee to come out slower.
Your next possible scenario is the pump. Vibratory pumps do go bad from time to time, and a bad pump would cause the coffee to come out slow.
If its a newer saeco machine with the J style boiler, it could be clogged due to lack of descaling.
Slow coffee can be caused by any one of these issues. Usually it is the first one.... the grinder settings.
A tip is to never go under the 3 setting under any saeco machine as the machines for some reason cannot handle anything lower all that well.
Also remember these machines are ment to produce an "espresso like" coffee, and not traditional espresso. They are not capable of producing espresso that you would otherwise be able to make in a traditional handle machine.
Hope this helps.
Mar 29, 2011 | Saeco Vienna SuperAutomatica Coffee...
Water is coffee is coming out very slow.. will descaling help???
Hi it sounds like it does need descaling i would do it more than once as it can build up and block the machine, once you have done this it will be back working again.
if you had no water or coffee coming out at all then i would say it has something else wrong with it like element etc, but as it is working but only slowly then descaling will solve your problem and should get it working as new again.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 25, 2010 | Keurig Coffee Makers & Espresso Machines
Water output too slow
Try to see how long takes whout coffee. If it is ok then the coffee is too fine or wed or the filter inside the holder need cleaning remove filter and wash it with hot water and brush so all holes to be open.
If after this you still have slow water without coffee the the pressure pump is not working properly and it need ither descaling or is complete damage so you need a new pump. Good luck.
Please remember to vote for this answer thanks
Feb 14, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Need gasket for Alessi 6 cup stove top espresso coffee maker
I have a Elevation Espresso Coffee Maker it worked fine until today when it stopped heating the water. Any help would be great.
Regards
frank
Jan 21, 2009 | Alessi "Coban" Espresso Machine
Saeco Primea new machine - slow dripping
look in manuel how to ajust the coffee grinder its grind the coffee to fine when you ajust the leveler of coffee move it only when the grinder work do a few ajustment it will be fine pierre
Dec 25, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Slow coffee drip
did you change coffee different coffee different setting lower our coffee setting move it only when it grinding only cheers
Dec 07, 2007 | Saeco Vienna Deluxe
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
274 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
